Zune Flash 2nd Generation Face Plate Replacement
  1. Zune Flash 2nd Generation Face Plate Replacement, Back Cover: step 1, image 1 of 2 Zune Flash 2nd Generation Face Plate Replacement, Back Cover: step 1, image 2 of 2
    • Prior to disassembly, verify the hold switch is engaged to ensure the device will not turn on during the procedure.
    • If the device turns on while it is being disassembled it could cause irreversible damage to the device.
    • PICS MAKE NO SENSE.
  2. Zune Flash 2nd Generation Face Plate Replacement: step 2, image 1 of 2 Zune Flash 2nd Generation Face Plate Replacement: step 2, image 2 of 2
    • Remove the top metal clip by inserting a Zune opening tool in between the faceplate and back cover and pulling gently back as shown in the images.
    • You should hear a 'click' as the clip detaches from the device.
  3. Zune Flash 2nd Generation Face Plate Replacement: step 3, image 1 of 1
    • Remove the two screws shown using a Y00 Tri-Wing screwdriver.
  4. Zune Flash 2nd Generation Face Plate Replacement: step 4, image 1 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 4, image 2 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 4, image 3 of 3
    • Insert the Zune opening tool between the faceplate and the back cover, starting from the top and slowly work your way around the device.
  5. Zune Flash 2nd Generation Face Plate Replacement: step 5, image 1 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 5, image 2 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 5, image 3 of 3
    • Work your way around the Zune until the back cover comes free. Remove the back plate and set it aside.
  6. Zune Flash 2nd Generation Face Plate Replacement, Face Plate: step 6, image 1 of 2 Zune Flash 2nd Generation Face Plate Replacement, Face Plate: step 6, image 2 of 2
    • Remove the three screws (5.5mm by 3mm) from the backside of the Zune using a small Tri-Wing screwdriver.
    • Be sure to put this set of screws aside since they are a different size than any other screws in the device.
  7. Zune Flash 2nd Generation Face Plate Replacement: step 7, image 1 of 2 Zune Flash 2nd Generation Face Plate Replacement: step 7, image 2 of 2
    • Use your finger or a Zune opening tool to pry back the two clear flaps.
    • Next lift the communications board that was being held down by the clear flaps.
    • Be careful not to accidentally detach the slim ribbon that connects between the communications board and the device.
  8. Zune Flash 2nd Generation Face Plate Replacement: step 8, image 1 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 8, image 2 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 8, image 3 of 3
    • Disconnect the ribbon with the plastic opening tool by flipping up the black plastic flap where the ribbon connects to the memory board.
    • Carefully pull the ribbon out of the memory board, ensuring that the black plastic flap is up before removal to avoid the ripping the ribbon.
  9. Zune Flash 2nd Generation Face Plate Replacement: step 9, image 1 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 9, image 2 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 9, image 3 of 3
    • Remove the battery by prying the battery off from the bottom with a Zune opening tool.
    • There is an adhesive between the battery and the device, therefore use a metal spudger to finish detaching the battery.
    • Be sure not to puncture the battery in any way when using the metal spudger.
  10. Zune Flash 2nd Generation Face Plate Replacement: step 10, image 1 of 2 Zune Flash 2nd Generation Face Plate Replacement: step 10, image 2 of 2
    • Remove the single screw under the battery using a small Tri-Wing screwdriver.
  11. Zune Flash 2nd Generation Face Plate Replacement: step 11, image 1 of 1
    • Disconnect the faceplate from the device by depressing the two tabs located near the middle of each of the sides using a metal spudger.
    • This will disconnect the last circuit board in the device from the center frame.
  12. Zune Flash 2nd Generation Face Plate Replacement: step 12, image 1 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 12, image 2 of 3 Zune Flash 2nd Generation Face Plate Replacement: step 12, image 3 of 3
    • Remove the faceplate by using a metal spudger to separate it from the remaining components.
ybahman
139 Reputation
4 Guides authored
Cal Poly, Team 9-20, Regan Fall 2009 Member of Cal Poly, Team 9-20, Regan Fall 2009
CPSU-REGAN-F09S9G20
5 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 12
All Time: 3,816
