Zte Avail 2 Display Replacement
  1. Zte Avail 2 Display Replacement, Battery: step 1, image 1 of 3 Zte Avail 2 Display Replacement, Battery: step 1, image 2 of 3 Zte Avail 2 Display Replacement, Battery: step 1, image 3 of 3
    • Before disassembling your ZTE Avail 2, be sure it is powered off.
    • Remove the back cover using the notch at the bottom of the device.
    • Pull the back cover from the front panel gently to remove it.
  2. Zte Avail 2 Display Replacement: step 2, image 1 of 2 Zte Avail 2 Display Replacement: step 2, image 2 of 2
    • Remove the battery by the notch in the back plate.
  3. Zte Avail 2 Display Replacement, Display: step 3, image 1 of 1
    • Using your J00 screwdriver, unscrew each of the 8 Philips head 1.19mm screws from the black plate of the device.
  4. Zte Avail 2 Display Replacement: step 4, image 1 of 2 Zte Avail 2 Display Replacement: step 4, image 2 of 2
    • Using a spudger or plastic opening tool, pull up from underneath the back plate and pop off the piece.
  5. Zte Avail 2 Display Replacement: step 5, image 1 of 2 Zte Avail 2 Display Replacement: step 5, image 2 of 2
    • Using the tweezers remove the 4 orange ribbon cables. Do this by lifting their corresponding black connectors and pulling the ribbon out.
  6. Zte Avail 2 Display Replacement: step 6, image 1 of 1
    • On the left side you will see a cellular antenna cable wire. Remove this wire by gently pulling it off.
  7. Zte Avail 2 Display Replacement: step 7, image 1 of 1
    • Lift and set aside the motherboard from lying on top of the silver plate (this may require some force because it is held on by adhesive).
  8. Zte Avail 2 Display Replacement: step 8, image 1 of 1
    • Using an opening tool, lift and remove the silver metal plate off the back of the device (use some force here).
  9. Zte Avail 2 Display Replacement: step 9, image 1 of 1
    • Pry open to separate the metal piece from the front screen attachment using a plastic spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
5 other people completed this guide.
dunnluke
237 Reputation
1 Guide authored
One Comment
My screen is completely white and I DON'T have to turn the power off, jus the screen off n on n still screen is white. I can't hardly see my apps. Plz tell me what's wrong with my phone. I was thinking somewhere along the lines of my LED cuz everything looks kind of like a negative photo.
Joyce - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 7
All Time: 965
