Zoomer Show Pony Speaker Replacement
  1. Zoomer Show Pony Speaker Replacement, Power and Volume Switch: step 1, image 1 of 3 Zoomer Show Pony Speaker Replacement, Power and Volume Switch: step 1, image 2 of 3 Zoomer Show Pony Speaker Replacement, Power and Volume Switch: step 1, image 3 of 3
    • Flip the pony over.
    • Remove the five Triangle 3 screws from underneath.
    • The pony will separate into a few pieces once the screws are removed.
  2. Zoomer Show Pony Speaker Replacement: step 2, image 1 of 3 Zoomer Show Pony Speaker Replacement: step 2, image 2 of 3 Zoomer Show Pony Speaker Replacement: step 2, image 3 of 3
    • Disconnect all of the wires between the head and leg sections.
    • To replace the power/volume switch, remove the two Phillips #0 screws from the switch.
    • Lift the switch out to replace.
  3. Zoomer Show Pony Speaker Replacement, Speaker: step 3, image 1 of 1
    • Remove the black bar by unscrewing the two triangle screws marked in yellow. These screws are recessed into the black bar so you may need an extender for your triangle bit.
  4. Zoomer Show Pony Speaker Replacement: step 4, image 1 of 2 Zoomer Show Pony Speaker Replacement: step 4, image 2 of 2
    • If you are not replacing the pony's speaker, skip the next bullet point.
    • Lift out the speaker, again making sure that it is disconnected, and replace with a new one.
Matthew Sutton
278 Reputation
2 Guides authored
USF Tampa, Team S20-G5, Passmore Spring 2018 Member of USF Tampa, Team S20-G5, Passmore Spring 2018
USFT-PASSMORE-S18S20G5
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 272
