Zoomer Jurassic World Indominus Rex Motherboard Replacement
  1. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Back Cover: step 1, image 1 of 1
    • Turn off and unplug Zoomer Jurassic World Indominus Rex from any power source before doing replacements.
    • Remove all eight (8) 9.3mm Phillips screws using Phillips #1 screwdriver.
  2. Zoomer Jurassic World Indominus Rex Motherboard Replacement: step 2, image 1 of 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: step 2, image 2 of 2
    • Pry apart the back cover of the Jurassic Indominus Rex and the rest of the body using a spudger.
    • Do not take out the back cover immediately as it it still attached to the motherboard by a wire.
  3. Zoomer Jurassic World Indominus Rex Motherboard Replacement: step 3, image 1 of 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: step 3, image 2 of 2
    • Disconnect the orange wire that connects the motherboard and the back cover.
    • Separate the back cover and the rest of the Zoomer Jurassic World Indominus Rex.
    • Gently press the tab on the side of the orange connector if you are having trouble disconnecting the wire.
  4. Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: step 4, image 1 of 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement, Motherboard: step 4, image 2 of 2
    • Let the toy rest firmly on a flat surface before processing to the next step.
    • Gently pull each wire out of the connector on the motherboard. Use a set of tweezers, if necessary.
  5. Zoomer Jurassic World Indominus Rex Motherboard Replacement: step 5, image 1 of 2 Zoomer Jurassic World Indominus Rex Motherboard Replacement: step 5, image 2 of 2
    • Remove the two (2) #0 7.5mm phillips screws from the left side of the motherboard.
    • Remove the one (1) 7.5mm #0 phillips screw from the right side of the motherboard.
  6. Zoomer Jurassic World Indominus Rex Motherboard Replacement: step 6, image 1 of 1
    • Use a soldering iron to remove the red and black wires from the motherboard .
    • Soldering technique guide from iFixit can be found here.
    • Using a soldering iron can be very dangerous! Handle with care to avoid being burned.
Anh Le
504 Reputation
3 Guides authored
USF Tampa, Team 10-3, Remmell Spring 2016 Member of USF Tampa, Team 10-3, Remmell Spring 2016
USFT-REMMELL-S16S10G3
4 Members
14 Guides authored
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 12
All Time: 773
