Zeki TBQG884B Camera Replacement
  1. Zeki TBQG884B Camera Replacement, Rear Case: step 1, image 1 of 2 Zeki TBQG884B Camera Replacement, Rear Case: step 1, image 2 of 2
    • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
  2. Zeki TBQG884B Camera Replacement: step 2, image 1 of 1
    • Place the tablet down so that the screen is facing away from you.
    • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
    • Gently work your way around the perimeter of the tablet's edge.
  3. Zeki TBQG884B Camera Replacement: step 3, image 1 of 2 Zeki TBQG884B Camera Replacement: step 3, image 2 of 2
    • Remove the back cover
    • Remove any tape on the speaker and detach the speaker from the back plate.
    • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
  4. Zeki TBQG884B Camera Replacement, Camera: step 4, image 1 of 2 Zeki TBQG884B Camera Replacement, Camera: step 4, image 2 of 2
    • Open the ZIF connector, the black lock part over the wire ribbon in the motherboard, and remove the wire ribbon that connects the motherboard and the camera.
    • The camera is located on the top left, above the motherboard.
    • The camera is usually covered with tape or material. Peel material/tape off with tweezers for safety.
2 other people completed this guide.
Natalie Holm
137 Reputation
1 Guide authored
IUPUI, Team 1-3, Harley Fall 2015 Member of IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 266
