Introduction
This guide will walk you through removing the underlying component of the feed key, or button, in order to replace it.
Remove 5 11.08mm Phillips screws that will come out of the casing once loose.
There is one Phillips screw at the bottom center set deep inside the casing - it is easy to get to with a thin screwdriver. This screw will come loose, but stay inside the casing. Don't be surprised when it won't drop out.
Position your hands one on either side of the top.
Put your thumbs on the front and your 4 fingers on the sides.
Push outwards with your 4 fingers to remove the plastic top.
Put the lid back down and lay the top open as shown in the photo.
The component we are replacing is on the underneath of the top of the device, highlighted in the photo
Starting with either ribbon cable, grip it on either side and gently pull out - The cable will come out of it's connector.
Repeat for other ribbon cable
Remove 2 7.51mm Phillips screws holding the circuit board onto the device casing.
