ZTE ZFive G LTE Volume and Power Button Replacement
  1. ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: step 1, image 1 of 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: step 1, image 2 of 3 ZTE ZFive G LTE Volume and Power Button Replacement, Volume and power button: step 1, image 3 of 3
    • Remove back cover of the device from the crease of the bottom left corner using opening tool or fingernail.
  2. ZTE ZFive G LTE Volume and Power Button Replacement: step 2, image 1 of 2 ZTE ZFive G LTE Volume and Power Button Replacement: step 2, image 2 of 2
    • Remove the battery with an opening tool or fingernail.
  3. ZTE ZFive G LTE Volume and Power Button Replacement: step 3, image 1 of 2 ZTE ZFive G LTE Volume and Power Button Replacement: step 3, image 2 of 2
    • Unscrew all 16 screws from the mid-frame with a J000 screwdriver.
  4. ZTE ZFive G LTE Volume and Power Button Replacement: step 4, image 1 of 2 ZTE ZFive G LTE Volume and Power Button Replacement: step 4, image 2 of 2
    • Being careful with the device, gently pull up the device body tugging from the inside of the device.
    • Be sure to pull away from the device.
  5. ZTE ZFive G LTE Volume and Power Button Replacement: step 5, image 1 of 2 ZTE ZFive G LTE Volume and Power Button Replacement: step 5, image 2 of 2
    • Carefully use a pair of bent nose tweezers to pull out the button cover. I should come out easily.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 306
