ZTE ZFive G LTE Back Camera Replacement
  1. ZTE ZFive G LTE Back Camera Replacement, Back Camera: step 1, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement, Back Camera: step 1, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement, Back Camera: step 1, image 3 of 3
    • Pry open back cover of the device from the crease at the bottom left corner with an opening tool or fingernail.
  2. ZTE ZFive G LTE Back Camera Replacement: step 2, image 1 of 2 ZTE ZFive G LTE Back Camera Replacement: step 2, image 2 of 2
    • Remove all 16 screws with a J000 screwdriver.
  3. ZTE ZFive G LTE Back Camera Replacement: step 3, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement: step 3, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement: step 3, image 3 of 3
    • Remove the battery with an opening tool or fingernail.
  4. ZTE ZFive G LTE Back Camera Replacement: step 4, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement: step 4, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement: step 4, image 3 of 3
    • Gently pry open the device body by tugging from the inside out, be sure to pull up and away from device.
  5. ZTE ZFive G LTE Back Camera Replacement: step 5, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement: step 5, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement: step 5, image 3 of 3
    • Once body is removed, back-facing camera is placed at the top left corner of device.
    • Using an opening tool, pull up the tab of the camera wire ribbon.
  6. ZTE ZFive G LTE Back Camera Replacement: step 6, image 1 of 3 ZTE ZFive G LTE Back Camera Replacement: step 6, image 2 of 3 ZTE ZFive G LTE Back Camera Replacement: step 6, image 3 of 3
    • Using the blunt-nose tweezers, tug at the camera gently, switching sides to remove adhesive little by little, pull camera out gently.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 212
