ZTE Tempo X Charging/Aux Board Replacement
  1. ZTE Tempo X Charging/Aux Board Replacement, Back Cover: step 1, image 1 of 2 ZTE Tempo X Charging/Aux Board Replacement, Back Cover: step 1, image 2 of 2
    • Remove back cover using the divot provided.
  2. ZTE Tempo X Charging/Aux Board Replacement, Battery: step 2, image 1 of 2 ZTE Tempo X Charging/Aux Board Replacement, Battery: step 2, image 2 of 2
    • Find the divot near the bottom of the battery and remove the battery from the device.
  3. ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: step 3, image 1 of 2 ZTE Tempo X Charging/Aux Board Replacement, Charging/Aux Board: step 3, image 2 of 2
    • Remove the sixteen 3mm screws using the Phillips #000 screwdriver.
  4. ZTE Tempo X Charging/Aux Board Replacement: step 4, image 1 of 2 ZTE Tempo X Charging/Aux Board Replacement: step 4, image 2 of 2
    • Take off the second back cover, lifting from the bottom of the device to the top.
  5. ZTE Tempo X Charging/Aux Board Replacement: step 5, image 1 of 3 ZTE Tempo X Charging/Aux Board Replacement: step 5, image 2 of 3 ZTE Tempo X Charging/Aux Board Replacement: step 5, image 3 of 3
    • Using a spudger, unclip the board from the phone at the places highlighted.
  6. ZTE Tempo X Charging/Aux Board Replacement: step 6, image 1 of 3 ZTE Tempo X Charging/Aux Board Replacement: step 6, image 2 of 3 ZTE Tempo X Charging/Aux Board Replacement: step 6, image 3 of 3
    • Use the spudger to remove the board from the phone.
    • The board is held by glue so there will be resistance when detaching it from the phone.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 209
