Introduction
Follow the steps on this guide to replace the motherboard of the ZTE Grand X Max Plus.
To remove the motherboard, you will need to open the phone and remove the battery first. These steps are included in this guide.
Heat the phone using a heating pad, heat gun, or hair dryer to loosen the glue. You just need to heat the back of the phone.
Carefully remove the cover from the phone.
Pics are a little dark. See if you can play with the white balance to correct this.
One Comment
Hello I recently repaired the screen on this same device by changing th whole front screen assembly with its frame. Once I finished the repair the phone seemed to function normally but now the phone cant connect to any network and keeps on thinking its on airplane mode. What could this be related to?
What if you have no heating element or source
mlp100686 - Reply
