ZTE Grand X Max Plus Back Cover Replacement
  1. ZTE Grand X Max Plus Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Make sure you turn off your phone before starting.
    • Heat the phone with a heating pad to loosen the glue. You just need to heat the back of the phone.
    • You can also use a hair dryer or a heating gun for this step.
  2. ZTE Grand X Max Plus Back Cover Replacement: step 2, image 1 of 2 ZTE Grand X Max Plus Back Cover Replacement: step 2, image 2 of 2
    • After the phone is heated, use the blue plastic opening tool on both sides of the phone.
    • Don't apply too much pressure because the cover can crack easily.
    • To avoid that your cover cracks, you can add tape to back cover.
    • You can use a suction cup to help remove the battery.
  3. ZTE Grand X Max Plus Back Cover Replacement: step 3, image 1 of 2 ZTE Grand X Max Plus Back Cover Replacement: step 3, image 2 of 2
    • Carefully remove the cover from the phone.
Jordano Baer
689 Reputation
5 Guides authored
USF Tampa, Team S9-G4, Remmell Fall 2017 Member of USF Tampa, Team S9-G4, Remmell Fall 2017
USFT-REMMELL-F17S9G4
4 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 468
