ZTE Blade Z Max Side Mounted Buttons Replacement
  1. ZTE Blade Z Max Side Mounted Buttons Replacement, SIM Card: step 1, image 1 of 3 ZTE Blade Z Max Side Mounted Buttons Replacement, SIM Card: step 1, image 2 of 3 ZTE Blade Z Max Side Mounted Buttons Replacement, SIM Card: step 1, image 3 of 3
    • Turn the device on it side with the buttons away from you.
    • Using the SIM Card Eject Tool, insert the narrow end into the ejection hole.
    • Press firmly into the hole until the SIM card tray pops out far enough to grab with your fingers.
  2. ZTE Blade Z Max Side Mounted Buttons Replacement: step 2, image 1 of 3 ZTE Blade Z Max Side Mounted Buttons Replacement: step 2, image 2 of 3 ZTE Blade Z Max Side Mounted Buttons Replacement: step 2, image 3 of 3
    • Pull the tray out with your fingers .
    • Remove the SIM card.
  3. ZTE Blade Z Max Side Mounted Buttons Replacement, Fingerprint Sensor: step 3, image 1 of 1
    • Remove the one T2 screw from the side of the phone near where the SIM card tray was.
  4. ZTE Blade Z Max Side Mounted Buttons Replacement: step 4, image 1 of 2 ZTE Blade Z Max Side Mounted Buttons Replacement: step 4, image 2 of 2
    • Insert a plastic opening tool into the space where the SIM card tray used to be.
    • Gently pry the back away form the phone frame until you hear and audible click of the back separating.
  5. ZTE Blade Z Max Side Mounted Buttons Replacement: step 5, image 1 of 2 ZTE Blade Z Max Side Mounted Buttons Replacement: step 5, image 2 of 2
    • Insert the plastic opening tool into the space you created between the phone back and frame.
    • Slide the plastic opening tool along the outside of the phone, underneath the back, to separate the rest of the clips holding the back onto the frame.
  6. ZTE Blade Z Max Side Mounted Buttons Replacement: step 6, image 1 of 2 ZTE Blade Z Max Side Mounted Buttons Replacement: step 6, image 2 of 2
    • Rotate the back over to the side, being careful not to damage the fingerprint sensor ribbon cable.
    • Use a plastic opening tool to separate the fingerprint sensor from the back of the phone.
    • On reassembly, add a piece of simple scotch tape to hold the fingerprint sensor to the phone back.
    • Set the phone back aside.
  7. ZTE Blade Z Max Side Mounted Buttons Replacement: step 7, image 1 of 1
    • Remove the 6 silver 2.9mm screws from the back of the phone with a JIS #000 bit.
    • Remove the 11 black 3.5mm screws with the same JIS #000 bit.
  8. ZTE Blade Z Max Side Mounted Buttons Replacement: step 8, image 1 of 2 ZTE Blade Z Max Side Mounted Buttons Replacement: step 8, image 2 of 2
    • Turn the phone over, with the screen up.
    • Insert the opening tool between the screen and the silver trim that surrounds it.
    • Run the plastic opening tool around the circumference of the phone to separate the clips of that hold the trim to the frame.
  9. ZTE Blade Z Max Side Mounted Buttons Replacement: step 9, image 1 of 2 ZTE Blade Z Max Side Mounted Buttons Replacement: step 9, image 2 of 2
    • Turn the phone back over, with the screen down.
    • Lift the trim piece off of the phone and set aside.
  10. ZTE Blade Z Max Side Mounted Buttons Replacement: step 10, image 1 of 2 ZTE Blade Z Max Side Mounted Buttons Replacement: step 10, image 2 of 2
    • Using a plastic opening tool, separate the fingerprint ribbon connector from the motherboard.
  11. ZTE Blade Z Max Side Mounted Buttons Replacement, Side Mounted Buttons: step 11, image 1 of 2 ZTE Blade Z Max Side Mounted Buttons Replacement, Side Mounted Buttons: step 11, image 2 of 2
    • Using a set of tweezers, pull off the small piece of tape on top of the ribbon cable connector on the left side of the motherboard.
  12. ZTE Blade Z Max Side Mounted Buttons Replacement: step 12, image 1 of 2 ZTE Blade Z Max Side Mounted Buttons Replacement: step 12, image 2 of 2
    • Use a plastic opening tool or spudger to scrape the glue away from the ribbon cable.
  13. ZTE Blade Z Max Side Mounted Buttons Replacement: step 13, image 1 of 3 ZTE Blade Z Max Side Mounted Buttons Replacement: step 13, image 2 of 3 ZTE Blade Z Max Side Mounted Buttons Replacement: step 13, image 3 of 3
    • Using a plastic opening tool or spudger, open the zip connection by prying up on the right (black) side of the connector.
    • Using the tweezers, carefully pull the the ribbon cable out of the connector.
  14. ZTE Blade Z Max Side Mounted Buttons Replacement: step 14, image 1 of 2 ZTE Blade Z Max Side Mounted Buttons Replacement: step 14, image 2 of 2
    • The button ribbon cable is very fragile, especially near the down volume button. If you intend on reinstalling this piece later, be careful not to rip it.
    • Using a plastic opening tool or tweezers, pry the edge of the button strip away from the phone.
    • Once all of the buttons are free, the whole assembly should simply lift out.
    • Glue may be required to hold the new buttons to the phone.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 13
All Time: 1,559
