ZTE Axon11 Display Replacement
    1. ZTE Axon11 Display Replacement, Remove Back Cover: step 1, image 1 of 1
      • Remove the Back Cover as you would do with any other Mobile ..
      Ask FixBot
    2. ZTE Axon11 Display Replacement: step 2, image 1 of 1
      • Get rid of Glue and plastic foils on top ..
      Ask FixBot
    3. ZTE Axon11 Display Replacement: step 3, image 1 of 1
      • Unscrew lower cover Part (As far as i remember there have been 7 screws) and lift it up
      Ask FixBot
    4. ZTE Axon11 Display Replacement: step 4, image 1 of 1
      • Under the cover part there is 1 screw left (this a tiny one, not like the other 7 ..)
      Ask FixBot
    5. ZTE Axon11 Display Replacement: step 5, image 1 of 2 ZTE Axon11 Display Replacement: step 5, image 2 of 2
      • Then lift this part away as well ..
      • Unscrew all screws form the upper cover part near the camera ..
      Ask FixBot
    6. ZTE Axon11 Display Replacement: step 6, image 1 of 1
      • Remove the battery. This is the hardest part. I tried from right side as seen in the Picture .. There are 2 flat cables on zthis side (connecting the motherboard and the lower electronics, so this might not be the best direction to start (see photos later). Try using fan (i did'nt have one) ..
      • The blue plastic shows the tiny screw which you need to unscrew to remove the whole upper plastic thing .. I'm not sure you need to remove that part to change the display ..
      Ask FixBot
    7. ZTE Axon11 Display Replacement: step 7, image 1 of 2 ZTE Axon11 Display Replacement: step 7, image 2 of 2
      • This is the accu removed .. You can see that I damaged one of the flat cables (seem to work though) .. You can see where most of the glue has been, so concentrate your work on this area. The right flat cable is the connector to the display (the other two connect Motherboard and sideboard).. unconnect it ..
      • You can remove the other flat cables too (but don't have to ..).
      Ask FixBot
    8. ZTE Axon11 Display Replacement: step 8, image 1 of 1
      • Remove the display form the front side .. Change the display, connect the flat cable as it has been .. Basically your are done now ..
      Ask FixBot
      • Put everything back again ..
      Ask FixBot
Arbeite die Schritte in umgekehrter Reihenfolge ab, um dein Gerät wieder zusammenzubauen.
Andreas Behal
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 39
All Time: 1,150
