Introduction
This guide walks you through replacing the RAM in a ZOTAC ZBOX MI642 Nano mini PC. The MI642 Nano is sold as a barebones unit, meaning it often ships without RAM pre-installed, and users may also receive the device secondhand with a faulty or incompatible memory module. Completing this replacement will restore normal system function, resolve boot failures caused by faulty RAM, and prepare a barebones unit for first use.
Never work on the device while it is plugged in. Failing to disconnect power before opening the device risks electric shock and permanent damage to internal components.
Shut down the ZOTAC ZBOX MI642 Nano completely through the operating system; do not simply put it to sleep. Once the device has fully powered off, disconnect the power cable from the rear of the unit.
Turn the ZBOX MI642 Nano upside-down and place it on a soft, clean surface such as a cloth mat or folded towel.
You've successfully replaced your RAM on your ZOTAC MI642 NANO Mini PC!
