ZCWA BR151 Water Filter Replacement
    1. ZCWA BR151 Water Filter Replacement, Water Tank: step 1, image 1 of 1
      • Turn off the device.
      Ask FixBot
    2. ZCWA BR151 Water Filter Replacement: step 2, image 1 of 2 ZCWA BR151 Water Filter Replacement: step 2, image 2 of 2
      • Remove the water tank by sliding the latch down with a finger and grasping the bottom of the water tank.
      • Pull it out.
      Ask FixBot
    1. ZCWA BR151 Water Filter Replacement, Water Filter: step 3, image 1 of 3 ZCWA BR151 Water Filter Replacement, Water Filter: step 3, image 2 of 3 ZCWA BR151 Water Filter Replacement, Water Filter: step 3, image 3 of 3
      • Remove the filter holders, on the bottom of the water tank, one at a time by maneuvering the spudger under the flaps of the filter holders.
      • Use the spudger to lift enough of the flap up to pinch it between two fingers.
      • Pull the flap up while pinching it to dislodge the filter holder from the water tank.
      Ask FixBot
    2. ZCWA BR151 Water Filter Replacement: step 4, image 1 of 3 ZCWA BR151 Water Filter Replacement: step 4, image 2 of 3 ZCWA BR151 Water Filter Replacement: step 4, image 3 of 3
      • To extract the cotton filters, push the flaps of the filter holders down.
      • Use the tweezers to pull out the filter.
      Ask FixBot
1 Guide Comment
How do you get the cotton filters back into the rubber holders ?
Bill - Reply Share
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 60
All Time: 904
