Yujin Robot iCLEBO Arte Filter Replacement
    1. Yujin Robot iCLEBO Arte Filter Replacement, Dust Bin: step 1, image 1 of 1
      • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
      Ask FixBot
    2. Yujin Robot iCLEBO Arte Filter Replacement: step 2, image 1 of 2 Yujin Robot iCLEBO Arte Filter Replacement: step 2, image 2 of 2
      • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
      • Empty contents of bin into waste receptacle and rinse with water as needed.
      Ask FixBot
    1. Yujin Robot iCLEBO Arte Filter Replacement, Filter: step 3, image 1 of 1
      • Push the yellow tab releasing the filter harness.
      Ask FixBot
    2. Yujin Robot iCLEBO Arte Filter Replacement: step 4, image 1 of 1
      • Replace or clean filter under a stream of water. When reinserting filter, make sure the filter's cut corner is in the correct corner.
      Ask FixBot
To finish reassembling your device, follow these instructions in reverse order.
Nathan Clark
101 Reputation
1 Guide authored
USF Tampa, Team S2-G3, Nance Spring 2017 Member of USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 84
All Time: 634
