Yujin Robot iCLEBO Arte Dust Bin Replacement
  1. Yujin Robot iCLEBO Arte Dust Bin Replacement, Dust Bin: step 1, image 1 of 1
    • Remove the dust bin by gently pressing the silver button on top of the vacuum until the bin releases.
  2. Yujin Robot iCLEBO Arte Dust Bin Replacement: step 2, image 1 of 2 Yujin Robot iCLEBO Arte Dust Bin Replacement: step 2, image 2 of 2
    • Grip the bottom of the dust bin. Push up on the tabs as indicated by the yellow arrows.
    • Empty contents of bin into waste receptacle and rinse with water as needed.
To reassemble the dust bin, follow these instructions in reverse order.
Trent Treiber
204 Reputation
2 Guides authored
USF Tampa, Team S2-G3, Nance Spring 2017 Member of USF Tampa, Team S2-G3, Nance Spring 2017
USFT-NANCE-S17S2G3
4 Members
14 Guides authored
3 Comments
My machine says C3 even though the dust bin is successfully in place. Now what? Works fine on hardwood floors.
Amy Abbiatti - Reply
C3 error even though dustbin is installed correctly. Works fine on hardwood floors. Now what?
I also get C3 error when dustbin is clean and installed correctly - now what?
Philip Melese - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 1,075
