Yoton YB02 Motion Sensor Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
54
All Time:
416
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the camera is not activating with detected movement, then the likely cause is a faulty motion sensor. Use this guide to replace the motion sensor of the YOTON YB02 which is within the camera part itself. The motion sensor of the camera detects the movement of the child and therefore activates the camera so the user can view it on the monitor. Before starting with this guide, make sure to clean the camera as a dirty camera could affect the performance of the motion sensor. Step 3 requires you to desolder the camera from the motherboard so a soldering iron device will be required. Be sure to completely turn off the device before beginning.
Tools
    1. Yoton YB02 Motion Sensor Replacement, Motion Sensor: step 1, image 1 of 2 Yoton YB02 Motion Sensor Replacement, Motion Sensor: step 1, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the single 7 mm screw from the back of the panel from the camera.
      Ask FixBot
    2. Yoton YB02 Motion Sensor Replacement: step 2, image 1 of 2 Yoton YB02 Motion Sensor Replacement: step 2, image 2 of 2
      • Use a metal spudger to pry off the back panel from the camera.
      • It is recommended to pry at the edges of the panel and run through the edge of the panel.
      Ask FixBot
    3. Yoton YB02 Motion Sensor Replacement: step 3, image 1 of 3 Yoton YB02 Motion Sensor Replacement: step 3, image 2 of 3 Yoton YB02 Motion Sensor Replacement: step 3, image 3 of 3
      • With the soldering iron, desolder the pins holding the camera in place onto the motherboard on the other side of the motherboard.
      • Carefully pry off the camera unit, including the motion sensor, with your hands.
      Ask FixBot
hsisson
811 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 54
All Time: 416
