Yoton YB02 Monitor Battery Replacement
    1. Yoton YB02 Monitor Battery Replacement, Monitor Battery: step 1, image 1 of 1
      • Use a Phillips #0 screwdriver to remove the four 7 mm screws from the back panel of the monitor.
      Ask FixBot
    2. Yoton YB02 Monitor Battery Replacement: step 2, image 1 of 2 Yoton YB02 Monitor Battery Replacement: step 2, image 2 of 2
      • Use a plastic opening tool to separate the back panel from the monitor.
      • It is recommended to start from a corner, and run the tool along the edge of the panel.
      Ask FixBot
    3. Yoton YB02 Monitor Battery Replacement: step 3, image 1 of 2 Yoton YB02 Monitor Battery Replacement: step 3, image 2 of 2
      • With the plastic tool, pry off the monitor battery from the motherboard.
      Ask FixBot
    4. Yoton YB02 Monitor Battery Replacement: step 4, image 1 of 3 Yoton YB02 Monitor Battery Replacement: step 4, image 2 of 3 Yoton YB02 Monitor Battery Replacement: step 4, image 3 of 3
      • Using the plastic tool, disconnect the cables connecting the battery to the motherboard.
      Ask FixBot
hsisson
811 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 61
All Time: 474
