Yoton YB02 Camera Stand Speaker Replacement
  1. Yoton YB02 Camera Stand Speaker Replacement, Camera Stand Speaker: step 1, image 1 of 2 Yoton YB02 Camera Stand Speaker Replacement, Camera Stand Speaker: step 1, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the single 7 mm screw from the back of the panel from the camera.
  2. Yoton YB02 Camera Stand Speaker Replacement: step 2, image 1 of 2 Yoton YB02 Camera Stand Speaker Replacement: step 2, image 2 of 2
    • Use a metal spudger to pry off the back panel from the camera.
    • It is recommended to pry at the edges of the panel and run through the edge of the panel.
  3. Yoton YB02 Camera Stand Speaker Replacement: step 3, image 1 of 1
    • Carefully move the motherboard out of the way to access the camera speaker.
  4. Yoton YB02 Camera Stand Speaker Replacement: step 4, image 1 of 1
    • Use a plastic opening tool to remove the camera speaker from the panel.
    • It is recommended to remove or scrape off the excess glue holding the camera in place.
  5. Yoton YB02 Camera Stand Speaker Replacement: step 5, image 1 of 3 Yoton YB02 Camera Stand Speaker Replacement: step 5, image 2 of 3 Yoton YB02 Camera Stand Speaker Replacement: step 5, image 3 of 3
    • With the plastic opening tool, detach the cable from the speaker to the motherboard at the clips.
hsisson
811 Reputation
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 102
