Yoto Generation 3 Mobility Adaptation
    1. Yoto Generation 3 Mobility Adaptation, Peel plastic overscreen: step 1, image 1 of 1
      • Gen 3 Specific- Gently peel the screen off the METAL splunger tool from ifixit. Run it around the inner plastic. Also turn your yoto off unless you want to be blinded
      • Gen 2- follow the SD guide provided online by Yoto. Return at the step after the rotary encoder is removed.
      Ask FixBot
    2. Yoto Generation 3 Mobility Adaptation, Unscrew LED motherboard cover: step 2, image 1 of 1
      • Keep your yoto off. There's about 200 screws. Unscrew them. Then pry off with the good ole metal spludger. Then gently pry up the green motherboard.
      Ask FixBot
    3. Yoto Generation 3 Mobility Adaptation, Gently remove button and unscrew the rotary encoder: step 3, image 1 of 1
      • Pop off the button by gently wedging the spludger and wiggling the orange plastic. Then use pliars to unscrew the hex nut
      Ask FixBot
    4. Yoto Generation 3 Mobility Adaptation, Unscrew and unplug: step 4, image 1 of 1
      • Unscrew the NFC card holder. Use the spludger to make sure there is no glue in the female connector socket on the motherboard for the NFC and the right hand button.
      Ask FixBot
    5. Yoto Generation 3 Mobility Adaptation, Thread your 4 pin JST 2.0 male through the hole and plug into motherboard: step 5, image 1 of 1
      • Thread your cable with shrink through the hole, Attach to motherboard. Put NFC back in and reassemble Yoto. This is the same for the Generation 2.
      • Now is the time to put the jacket back on.
      Ask FixBot
    6. Yoto Generation 3 Mobility Adaptation, Connect to 3D printed parts: step 6, image 1 of 1
      • Connect to female side of cable and insert the rotary encoder into the 3d printed part. it is a tight fit so be sure to go slow and secure tighlty
      Ask FixBot
    7. Yoto Generation 3 Mobility Adaptation, Connect the button to the Yoto: step 7, image 1 of 1
      • Connect the wires. Yellow to yellow, red to read, black to black and white to white. Coer with heat shrink tubing. You can solder or just twist.
      Ask FixBot
RaeL
490 Reputation
3 Guides authored
3 Guide Comments
Thank you! This is the only set of instructions I've found for how to open up a 3rd gen Yoto! I order the spudger set and the tool worked perfectly.
yotorocks - Reply Share
can we replace the sd card?
Amelia - Reply Share
Do you know the audio port black replacement piece size? Ours has a broken headphone piece stuck and will not come out Yoto will
Not replace
Brittany Funes - Reply Share
Past 24 Hours: 19
Past 7 Days: 108
Past 30 Days: 454
All Time: 5,075
