YT-88 Automatic Intelligent Sweeping Robot Full Disassembly
    1. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Starting to Disassemble: step 1, image 1 of 2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Starting to Disassemble: step 1, image 2 of 2
      • Turn the robot vacuum upside down to access the screws underneath.
      Ask FixBot
    2. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the battery: step 2, image 1 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the battery: step 2, image 2 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the battery: step 2, image 3 of 3
      • Using a Phillips 1 screw bit - remove the battery cover and carefully unplug the 18650 rechargeable cell from connector and place it in a safe separate environment along with the battery cover.
      Ask FixBot
    3. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the sweepers: step 3, image 1 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the sweepers: step 3, image 2 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the sweepers: step 3, image 3 of 3
      • Using a Phillips #1 screw bit remove the screws from both of the sweepers and using a slight force or using the shaft of the driver for leverage, remove the sweepers.
      Ask FixBot
    4. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Top Cover: step 4, image 1 of 2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Top Cover: step 4, image 2 of 2
      • Using a Phillips #1 driver, remove 6 screws from the base of the vacuum and carefully remove the top cover.
      Ask FixBot
    5. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disassembling the Top Cover: step 5, image 1 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disassembling the Top Cover: step 5, image 2 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disassembling the Top Cover: step 5, image 3 of 3
      • With the top cover now removed we can remove the clipping lid holding the dust box inside which can also be lifted out and removed.
      Ask FixBot
    6. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Dust Box: step 6, image 1 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Dust Box: step 6, image 2 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Dust Box: step 6, image 3 of 3
      • With the dust box removed we can open the latching lid and remove the dust filter by lifting it up from the provided tabs.
      Ask FixBot
    7. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing drive belts: step 7, image 1 of 1
      • Back in the internals of the vacuum all located in the bottom cover, the sweeper's drive belts can be then removed easily as they have slack - use the shaft of the screw driver if there are difficulties removing them.
      Ask FixBot
    8. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disconnecting the drive motor, impeller & UV light bar: step 8, image 1 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disconnecting the drive motor, impeller & UV light bar: step 8, image 2 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Disconnecting the drive motor, impeller & UV light bar: step 8, image 3 of 3
      • Carefully using your fingers, the a flat head screwdriver or recommended tweezers, remove the three JST connectors from the PCB which connect the impeller, drive motor assembly and UV light bar.
      Ask FixBot
    9. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the PCB: step 9, image 1 of 2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the PCB: step 9, image 2 of 2
      • With the PCB now disconnected from the components, the PCB can be removed with a Phillips #1 driver. Put this carefully to one side.
      • Keep in mind the battery connecter needs to be fed through the battery compartment as it is soldered to the board.
      Ask FixBot
    10. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Impeller Assembly: step 10, image 1 of 2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the Impeller Assembly: step 10, image 2 of 2
      • Using a Phillips #1 driver remove two screws that are holding the impeller assembly to the chassis - you can lift the assembly from the posts.
      Ask FixBot
    11. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the loose parts: step 11, image 1 of 2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the loose parts: step 11, image 2 of 2
      • There are two parts that are loose as they used to be held in by the covers being together.
      • The exhaust cover and fake sensor bar can be lifted up and placed aside.
      Ask FixBot
    12. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the UV light Bar: step 12, image 1 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the UV light Bar: step 12, image 2 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the UV light Bar: step 12, image 3 of 3
      • Using a Phillips #1 driver remove two screws that are holding the UV light bar in place keep this aside.
      Ask FixBot
    13. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Teardown the driver assembly: step 13, image 1 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Teardown the driver assembly: step 13, image 2 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Teardown the driver assembly: step 13, image 3 of 3
      • Using a Phillips #1 driver remove two screws holding the latched cover in place which will reveal the wheels attached to a shaft. You will need to use some tweezers or a flat head driver to carefully release the clips.
      Ask FixBot
    14. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the driving assembly: step 14, image 1 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the driving assembly: step 14, image 2 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the driving assembly: step 14, image 3 of 3
      • Using a Phillips #1 driver remove 4 screws holding the driver motor assembly in place - lift this up and keep it aside.
      Ask FixBot
    15. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the rubber seal: step 15, image 1 of 2 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Removing the rubber seal: step 15, image 2 of 2
      • Using a Phillips #1 driver, remove two screws securing the rubber seal that creates a tight seal with the floor for the suction. This can be easily removed from it's location.
      Ask FixBot
    16. YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Impeller: step 16, image 1 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Impeller: step 16, image 2 of 3 YT-88 Automatic Intelligent Sweeping Robot Full Disassembly, Tearing down the Impeller: step 16, image 3 of 3
      • The Impeller assembly can be teared down even further for access such as maintenance or cleaning.
      • There are a few plastic clips that need to be carefully unlatched - use a flat head driver or a shim to do this. Take extra caution as some clips might be brittle and will snap with excessive force.
      Ask FixBot
Frankie Pang
253 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 25
Past 30 Days: 71
All Time: 552
