YCCTEAM YCC-SW4001 Shoulder Buttons Replacement
    1. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Front Case: step 1, image 1 of 1
      • Use a Phillips screwdriver to remove the eight 9.15 mm screws that secure the rear case.
      Ask FixBot
    2. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 2, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 2, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 2, image 3 of 3
      • Use an opening pick to pry the back cover off of the controller.
      Ask FixBot
    3. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 3, image 1 of 1
      • Use a Phillips screwdriver to remove the three 9.15 mm screws from the back of the controller.
      Ask FixBot
    4. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Remove two additional screws: step 4, image 1 of 1
      • On some models there are two more Phillips head screws on the sides that need to be removed before the front and back panels can be separated.
      Ask FixBot
    5. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 5, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 5, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 5, image 3 of 3
      • Slightly lift the front case.
      • Do not remove the front cover completely; it is still attached to the motherboard by a white ribbon cable.
      Ask FixBot
    6. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 6, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 6, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 6, image 3 of 3
      • Use the tip of the opening pick to flip up the black locking flap of the ZIF connector.
      • The black flap holds the white ribbon cable in place.
      Ask FixBot
    7. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 7, image 1 of 2 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 7, image 2 of 2
      • Use tweezers to disconnect the white ribbon cable from the ZIF connector.
      Ask FixBot
    8. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 8, image 1 of 1
      • Remove the front case.
      Ask FixBot
    1. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: step 9, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: step 9, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement, Shoulder Buttons: step 9, image 3 of 3
      • Flip over the front cover and remove the four 5.8 mm screws from the rear of the front cover using a Phillips screwdriver.
      Ask FixBot
    2. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 10, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 10, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 10, image 3 of 3
      • Flip up the ZIF locking flap.
      Ask FixBot
    3. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 11, image 1 of 2 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 11, image 2 of 2
      • Disconnect the cable from the ZIF connector using tweezers or by hand.
      Ask FixBot
    4. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 12, image 1 of 2 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 12, image 2 of 2
      • Remove the circuit board and shoulder buttons assembly from the front cover.
      Ask FixBot
    5. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 13, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 13, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 13, image 3 of 3
      • Remove the R button by hand.
      Ask FixBot
    6. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 14, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 14, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 14, image 3 of 3
      • Remove the L button by hand.
      • Flip the shoulder buttons attachment and look at the metal rods.
      Ask FixBot
    7. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 15, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 15, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 15, image 3 of 3
      • Remove the metal rod under "ZL" using the small needle nose pliers.
      Ask FixBot
    8. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 16, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 16, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 16, image 3 of 3
      • Remove the metal rod under "ZR" using small needle nose pliers.
      Ask FixBot
    9. YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 17, image 1 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 17, image 2 of 3 YCCTEAM YCC-SW4001 Shoulder Buttons Replacement: step 17, image 3 of 3
      • Remove the ZL and ZR buttons by hand.
      Ask FixBot
Sam Borwick
333 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 70
All Time: 548
