Up to 20% off select tools
Xiaomi Redmi Note Midframe Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
11
All Time:
335
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Tools
    1. Xiaomi Redmi Note Midframe Replacement, Battery: step 1, image 1 of 1
      • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
      • Insert the plastic opening tool between the charging port and the rear case.
      • Pry the end of the rear case up from the charging port.
      Ask FixBot
    2. Xiaomi Redmi Note Midframe Replacement: step 2, image 1 of 2 Xiaomi Redmi Note Midframe Replacement: step 2, image 2 of 2
      • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
      Ask FixBot
    3. Xiaomi Redmi Note Midframe Replacement: step 3, image 1 of 2 Xiaomi Redmi Note Midframe Replacement: step 3, image 2 of 2
      • Locate the indentation at the bottom of the battery.
      • Place a finger in the indentation and lift up to remove the battery.
      Ask FixBot
    1. Xiaomi Redmi Note Midframe Replacement, Midframe: step 4, image 1 of 2 Xiaomi Redmi Note Midframe Replacement, Midframe: step 4, image 2 of 2
      • Remove twelve 3.5mm Phillips #00 screws from the midframe.
      Ask FixBot
    2. Xiaomi Redmi Note Midframe Replacement: step 5, image 1 of 2 Xiaomi Redmi Note Midframe Replacement: step 5, image 2 of 2
      • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
      • Run the plastic opening tool along the seam.
      • Pry up the midframe with the plastic opening tool.
      • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
      • There will be snapping sounds as the clips on the midframe disconnect from the phone.
      Ask FixBot
Author
with
Zongyi Li
1,653 Reputation
3 Guides authored
Cal Poly, Team S22-G4, Livingston Spring 2017 Member of Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 335
