Xiaomi ROBOROCK S5 Battery Replacement
  1. Xiaomi ROBOROCK S5 Battery Replacement, Battery: step 1, image 1 of 3 Xiaomi ROBOROCK S5 Battery Replacement, Battery: step 1, image 2 of 3 Xiaomi ROBOROCK S5 Battery Replacement, Battery: step 1, image 3 of 3
    • Power down your Roborock S5 vacuum.
    • Place it on a flat work surface with the wheels facing up.
    • Use a Phillips #2 screwdriver to remove the seven 14 mm screws holding the bottom cover in place.
    • Use the Phillips #2 screwdriver to loosen one captive screw holding the side brush in place.
    • Remove the side brush and set it aside for now.
    • Gently remove the bottom panel.
  2. Xiaomi ROBOROCK S5 Battery Replacement: step 2, image 1 of 1
    • Lift the battery out by the two tabs on top and set it beside the robot vacuum.
    • The battery will still be attached to the robot vacuum at this point.
  3. Xiaomi ROBOROCK S5 Battery Replacement: step 3, image 1 of 3 Xiaomi ROBOROCK S5 Battery Replacement: step 3, image 2 of 3 Xiaomi ROBOROCK S5 Battery Replacement: step 3, image 3 of 3
    • Disconnect the battery from the robot vacuum by squeezing and pulling the plug connector from the board.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 86
Past 30 Days: 381
All Time: 2,787
