This translation may not reflect the most recent updates from the source guide. Help update the translation or view the source guide.
Xiaomi Air Fryer NTC thermistor failure – Error E1
  1. Xiaomi Air Fryer NTC thermistor failure – Error E1, 200K Ohm NTC thermistor: step 1, image 1 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1, 200K Ohm NTC thermistor: step 1, image 2 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1, 200K Ohm NTC thermistor: step 1, image 3 of 3
    • Document dedicated to the test of the 200 K ohm NTC temperature probe of the AIR FRYER XIAOMI hot air fryer, applies to this fryer and many others very similar
    • PHOTO 3: NTC PROBE is located next to the resistance.
  2. Xiaomi Air Fryer NTC thermistor failure – Error E1: step 2, image 1 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 2, image 2 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 2, image 3 of 3
    • Images showing the machine displaying Error E1 that will trigger roughly after a minute of being on. It can occasionally work normally by turning it on and off.
  3. Xiaomi Air Fryer NTC thermistor failure – Error E1: step 3, image 1 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 3, image 2 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 3, image 3 of 3
    • Image 1: Display of Error E1 which prevents the machine from functioning.
    • Image 2: View of the NTC probe connector on the control board.
    • Photo 3: Location of the NTC thermistor cartridge as seen from the outside.
    • For the disassembly of the machine, you can use the following document and the videos linked within it as your reference.
  4. Xiaomi Air Fryer NTC thermistor failure – Error E1: step 4, image 1 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 4, image 2 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 4, image 3 of 3
    • Guide for a homemade hooking tool to take apart the air fryer's NTC thermistor probe.
  5. Xiaomi Air Fryer NTC thermistor failure – Error E1: step 5, image 1 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 5, image 2 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 5, image 3 of 3
    • Bill of materials required for the test:
    • Multimeter with a 200K Ohm scale.
    • Sewing needles, since the probe connector is quite small.
    • A strip of electrical tape.
  6. Xiaomi Air Fryer NTC thermistor failure – Error E1: step 6, image 1 of 2 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 6, image 2 of 2
    • Image 1: Damaged/broken NTC air fryer probe.
    • Image 2: Replacement NTC 200K Ohm thermistor acquired from Aliexpress/Amazon.
  7. Xiaomi Air Fryer NTC thermistor failure – Error E1: step 7, image 1 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 7, image 2 of 3 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 7, image 3 of 3
    • Insert 2 sewing needles into the 2 connector terminals as shown in image 1.
    • Connect one end of an alligator clip to each one of the sewing needles and connect the other end of the wire to the multimeter as shown in image 2.
    • Place some electrical tape in between the red and black alligator clips to electrically isolate them from each other as shown in image 3.
  8. Xiaomi Air Fryer NTC thermistor failure – Error E1: step 8, image 1 of 2 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 8, image 2 of 2
    • The two alligator clips should be electrically isolated as shown in the image.
  9. Xiaomi Air Fryer NTC thermistor failure – Error E1: step 9, image 1 of 1
    • Check the initial reading: At 25ºC (or anywhere near that temperature), the thermistor must have a resistance of roughly 100K Ohms.
  10. Xiaomi Air Fryer NTC thermistor failure – Error E1: step 10, image 1 of 2 Xiaomi Air Fryer NTC thermistor failure – Error E1: step 10, image 2 of 2
    • Apply heat to the thermistor/probe using a heat gun or a lighter. The probe resistance readings should gently decrease as the temperature increases. Since this one is damaged, it works unpredictably. Refer to the video for more clarification.
    • Youtube video that goes explaining each step, comparing the behavior of a malfunctioning probe with a normal one.
The disassembly of the machine and the extraction of the probe are detailed in another guide I have written.
2 other people completed this guide.
Special thanks to these translators:
es en
92%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
68,934 Reputation
220 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,697 Guides authored
4 Comments
Excellent clear guide. I have a Philips Essential XL HD9280 Airfryer, will it also have a 200K Ohm NTC Thermistor. I guess they are fairly generic in terms of design.
Paul Wilson - Reply
I'd try with a 100K Ohm NTC thermistor instead of a 200K since they are more commonly used. Try measuring the resistance with a multimeter at room temperature to see if it is within the vicinity of 100K or 200K and buy an NTC thermistor with a similar value. Don't hesitate to ask if you have any questions.
David -
Traducido:
Excelente guía clara. Tengo una Philips Essential XL HD9280 Airfryer, ¿tendrá también un termistor NTC de 200K Ohm. Supongo que son bastante genéricos en términos de diseño.
Todas las freidoras de aire son muy similares, casi seguro tiene uno similar o el mismo.
Carlos López (España - Spain) - Reply
Traducido:
Yo probaría con un termistor NTC de 100K Ohm en lugar de uno de 200K ya que son los más utilizados. Prueba a medir la resistencia con un polímetro a temperatura ambiente para ver si está en el entorno de 100K o 200K y compra un termistor NTC con un valor similar. No dudes en preguntar si tienes alguna duda.
Past 24 Hours: 18
Past 7 Days: 75
Past 30 Days: 282
All Time: 3,213
