Xiaomi Air 12 Screen Replacement
      • Remove the screws on the back. 1 of them is under the rubber pads in the center
      • Remove the back gently. Screen replacement stick can help. There are several plastic holding it.
      Ask FixBot
      • Remove the connectors going to the screen. 2 wifi cables near the battery. One camera cable halfway to the carger. One screen cable on at the HDMI.
      • Remove the screws holding the hinges on the corners. 4 screws holding them.
      Ask FixBot
      • Turn the hinges upwards till 90 degrees.
      • Remove the screen from the main board.
      Ask FixBot
      • Remove 2 screws from the bottom.
      • pull the screen towards the place of the screws and it will come out.
      Ask FixBot
      • Remove the screen. Remove the connector cable.
      • Check if the cable was wrong not the whole screen.
      Ask FixBot
      • Do everything backwards.
      • Connect the cable.
      • Push the new screen away from the places of the screws.
      • Add the screws.
      • Put back the whole together. Turn the hinges back.
      • Add the screws to the holes marked with a triangle.
      • Reconnect the cables to the main board.
      • Put back the lid of the main board.
      Ask FixBot
Finish Line
Robin Csutorás
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 86
All Time: 1,511
