Xbox Series X Center Chassis Assembly Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Xbox Series X Center Chassis Assembly Replacement, Uncover the back panel screws: step 1, image 1 of 2 Xbox Series X Center Chassis Assembly Replacement, Uncover the back panel screws: step 1, image 2 of 2
    Tool used on this step:
    Buy
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X Center Chassis Assembly Replacement: step 2, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement: step 2, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement: step 2, image 3 of 3
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X Center Chassis Assembly Replacement, Remove the back panel screws: step 3, image 1 of 1
    Magnetic Project Mat
    $19.95
    Buy
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X Center Chassis Assembly Replacement, Unclip the back panel: step 4, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Unclip the back panel: step 4, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Unclip the back panel: step 4, image 3 of 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X Center Chassis Assembly Replacement: step 5, image 1 of 2 Xbox Series X Center Chassis Assembly Replacement: step 5, image 2 of 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X Center Chassis Assembly Replacement, Remove the back panel: step 6, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Remove the back panel: step 6, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Remove the back panel: step 6, image 3 of 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X Center Chassis Assembly Replacement: step 7, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement: step 7, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement: step 7, image 3 of 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X Center Chassis Assembly Replacement, Remove the fan screws: step 8, image 1 of 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X Center Chassis Assembly Replacement, Disconnect the fan cable: step 9, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Disconnect the fan cable: step 9, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Disconnect the fan cable: step 9, image 3 of 3
    Buy
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X Center Chassis Assembly Replacement, Remove the fan: step 10, image 1 of 2 Xbox Series X Center Chassis Assembly Replacement, Remove the fan: step 10, image 2 of 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you are replacing the fan, a new fan will probably not include the plastic installation bracket. The bracket is attached to the fan with four T10 Torx screws. This is not pictured in this guide.
  11. Xbox Series X Center Chassis Assembly Replacement, Unlatch the base: step 11, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Unlatch the base: step 11, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Unlatch the base: step 11, image 3 of 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X Center Chassis Assembly Replacement, Twist and remove the base: step 12, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Twist and remove the base: step 12, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Twist and remove the base: step 12, image 3 of 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X Center Chassis Assembly Replacement, Remove the optical drive screws: step 13, image 1 of 2 Xbox Series X Center Chassis Assembly Replacement, Remove the optical drive screws: step 13, image 2 of 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X Center Chassis Assembly Replacement, Remove the vibration isolator: step 14, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Remove the vibration isolator: step 14, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Remove the vibration isolator: step 14, image 3 of 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X Center Chassis Assembly Replacement, Disconnect the power and data cables: step 15, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Disconnect the power and data cables: step 15, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Disconnect the power and data cables: step 15, image 3 of 3
    Buy
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X Center Chassis Assembly Replacement, Remove the optical drive: step 16, image 1 of 2 Xbox Series X Center Chassis Assembly Replacement, Remove the optical drive: step 16, image 2 of 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X Center Chassis Assembly Replacement, Disconnect the USB port cable: step 17, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Disconnect the USB port cable: step 17, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Disconnect the USB port cable: step 17, image 3 of 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X Center Chassis Assembly Replacement: step 18, image 1 of 2 Xbox Series X Center Chassis Assembly Replacement: step 18, image 2 of 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to remove the USB port cable from the center chassis.
    • Pull only on the pull tab, not the cable itself.
  19. Xbox Series X Center Chassis Assembly Replacement, Disconnect the power button cable: step 19, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Disconnect the power button cable: step 19, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Disconnect the power button cable: step 19, image 3 of 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X Center Chassis Assembly Replacement, Remove the chassis screws: step 20, image 1 of 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X Center Chassis Assembly Replacement, Peel up the USB port cable: step 21, image 1 of 2 Xbox Series X Center Chassis Assembly Replacement, Peel up the USB port cable: step 21, image 2 of 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
  22. Xbox Series X Center Chassis Assembly Replacement, Remove the center chassis assembly: step 22, image 1 of 3 Xbox Series X Center Chassis Assembly Replacement, Remove the center chassis assembly: step 22, image 2 of 3 Xbox Series X Center Chassis Assembly Replacement, Remove the center chassis assembly: step 22, image 3 of 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
    • Lift up the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
Carsten Frauenheim
116,119 Reputation
339 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,520 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 82
