Introduction
This guide will explain how to disassemble the Xbox DVD Drive in order to preform repairs or remove a stuck game by manually ejecting the drive.
You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
Lift the plastic hard drive carrier out of the Xbox case.
Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
Remove the disk drive. It should come right out.
Unplug the ribbon cable and yellow cables from back of disk drive.
Pry back the black plastic tabs around the disk drive in order to remove it from its housing. Once removed, set the drive aside.
Remove 4 PH1 Screws
Once screws are removed, lift the bottom half of the case up and away from the drive.
Flip the drive over and remove the top half of the case.
Press outwards on the 2 plastic retaining tabs
Gently lift PCB over tabs
Only remove these ribbon cables if you need to remove the entire PCB. These are friction fit ribbon cables. In my case, they have a piece of tape holding the ribbon to the connector
Using your screwdriver, or anything slim enough to fit, gently push the white lever back. Put your object on the right hand side of the lever, slightly pushing right as you push back.
The lens will drop down and your drive door will open about a quarter inch.
Gently pull the tray to its open position. If you have a game stuck in your drive, this would be the ideal time to remove it.
Remove the drive belt and replace it with a new one. Belts approximate location highlighted.
