Introduction
This guide covers how to remove the Blu Ray disk drive in the Xbox One X. This is a straightforward process once the outer shell of the Xbox has been removed.
Use a T9 Torx screwdriver to remove the 13mm screw which is under and to the left of the power input.
Orient the case so that the front of the Xbox (the side with the power button) is facing you.
Remove the top of the case by sliding the case towards you.
Using a T9 Torx screwdriver, remove the two 15mm silver screws that are holding a circuit board/panel to the side of the interior metal casing.
Using the same screwdriver, remove the 9mm black screw located farther to the right on the same circuit board/panel.
Pull the upper edge of the white clip down, and then remove the white connector from the dislocated panel using precision tweezers.
On the top of the device in the corner directly above the white connector, there is an oval plate held in place by two screws.
Remove both of these 7mm screws with a Torx T9 screwdriver.
Lift the detached plate off to the side.
Use a Torx T9 screwdriver to remove the six 47mm long screws, which attach the bottom side of the outer case.
Turn the Xbox over, so that the bottom of the case is on top.
Lift the bottom of the case off of the Xbox by pulling it up and toward you.
Flip over the device again, so that the top is facing upwards.
Remove the 4 smaller 11mm screws in the lower left corner on the metal casing using a Torx T9 screwdriver.
Flip over the device again, so that the bottom is facing upwards.
Using a Torx T9 screwdriver, remove the two screws located on opposite sides of the metal casing. One is near the fan vent, and the other is near the power supply vent.
Remove the metal casing by pulling it upward, revealing the interior components of the device.
Using your fingers, gently unplug the two sets of wires connecting the drive to the motherboard.
Alternatively, you can disconnect the wires from the drive-side sockets.
The BD drive should now be completely detached from the rest of the device, and it can be set aside.
