Xbox One Wireless Controller Bottom Motherboard Replacement
Views: 69K
View statistics:
Past 24 Hours:
8
Past 7 Days:
56
Past 30 Days:
277
All Time:
68,651
Comments: 63
52 comments on steps, 11 guide comments.
Go to guide comments
Completed: 31
31 people have marked this guide "completed." Will you be next?
Favorites: 6
6 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
This guide will show you how to remove the motherboards in order to access the buttons and triggers.
Parts
Tools
    1. Xbox One Wireless Controller Bottom Motherboard Replacement, Battery Pack: step 1, image 1 of 1
      • Remove the battery pack cover.
      • Remove batteries.
      Ask FixBot
    2. Xbox One Wireless Controller Bottom Motherboard Replacement, Side Handles: step 2, image 1 of 2 Xbox One Wireless Controller Bottom Motherboard Replacement, Side Handles: step 2, image 2 of 2
      • We recommend using a nylon spudger for this step. A metal spudger is shown.
      • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
      • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
      Ask FixBot
    3. Xbox One Wireless Controller Bottom Motherboard Replacement, Screws: step 3, image 1 of 2 Xbox One Wireless Controller Bottom Motherboard Replacement, Screws: step 3, image 2 of 2
      • There is a hidden screw located in the middle of the controller behind the label.
      • Use a screwdriver and punch a hole directly in the center of the label.
      • You may also lift the label if you do not want to puncture it.
      • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
      Ask FixBot
    4. Xbox One Wireless Controller Bottom Motherboard Replacement, Backplate: step 4, image 1 of 1
      • Remove the backplate.
      Ask FixBot
    5. Xbox One Wireless Controller Bottom Motherboard Replacement, Faceplate: step 5, image 1 of 1
      • Remove the faceplate.
      Ask FixBot
    1. Xbox One Wireless Controller Bottom Motherboard Replacement, Top Motherboard: step 6, image 1 of 2 Xbox One Wireless Controller Bottom Motherboard Replacement, Top Motherboard: step 6, image 2 of 2
      • You may let the rumble motors hang freely out of their sockets.
      • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
      • De-solder the black and gray wires that are attached to the top motherboard.
      • Remove the rumble motors and set them aside.
      • Be careful while using the soldering iron not to damage other components or hurt yourself.
      • For information on how to solder, click here.
      Ask FixBot
    2. Xbox One Wireless Controller Bottom Motherboard Replacement: step 7, image 1 of 1
      • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
      Ask FixBot
    3. Xbox One Wireless Controller Bottom Motherboard Replacement: step 8, image 1 of 1
      • Firmly grip sides of motherboard near the middle.
      • Lift upwards while slightly wiggling the motherboard forward and backward.
      • Lifting the motherboard will require some force.
      Ask FixBot
    1. Xbox One Wireless Controller Bottom Motherboard Replacement, Trigger Rumble Motors: step 9, image 1 of 1
      • Remove the yellow tape holding the wires in place on the front of the controller.
      Ask FixBot
    2. Xbox One Wireless Controller Bottom Motherboard Replacement: step 10, image 1 of 3 Xbox One Wireless Controller Bottom Motherboard Replacement: step 10, image 2 of 3 Xbox One Wireless Controller Bottom Motherboard Replacement: step 10, image 3 of 3
      • Unscrew the two 7mm T6 Hex screws located on underside the triggers.
      Ask FixBot
    3. Xbox One Wireless Controller Bottom Motherboard Replacement: step 11, image 1 of 1
      • Remove the trigger covers.
      Ask FixBot
    4. Xbox One Wireless Controller Bottom Motherboard Replacement: step 12, image 1 of 1
      • Desolder the wires from the motherboard.
      • Remove the rumble motors from its socket and pull the wire with it.
      Ask FixBot
    1. Xbox One Wireless Controller Bottom Motherboard Replacement, Bottom Motherboard: step 13, image 1 of 2 Xbox One Wireless Controller Bottom Motherboard Replacement, Bottom Motherboard: step 13, image 2 of 2
      • Remove the six T6 Torx screws located on the bottom motherboard.
      Ask FixBot
    2. Xbox One Wireless Controller Bottom Motherboard Replacement: step 14, image 1 of 2 Xbox One Wireless Controller Bottom Motherboard Replacement: step 14, image 2 of 2
      • Remove the bumpers by prying them off of the pegs that secure them, using a spudger. They are located on the front and back of the controller.
      • A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
      Ask FixBot
    3. Xbox One Wireless Controller Bottom Motherboard Replacement: step 15, image 1 of 2 Xbox One Wireless Controller Bottom Motherboard Replacement: step 15, image 2 of 2
      • Lift the piece surrounding the Home button off of its pegs.
      • Pry it off of the other side, using a spudger on the pins.
      • Removing this piece may require a lot of force.
      Ask FixBot
    4. Xbox One Wireless Controller Bottom Motherboard Replacement: step 16, image 1 of 1
      • Remove the bottom motherboard.
      Ask FixBot
31 other people completed this guide.
Liam Gow
5,600 Reputation
3 Guides authored
Cal Poly, Team 20-15, Maness Winter 2015 Member of Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Members
96 Guides authored
11 Guide Comments
Is de-soldering optional?
John Gonzalez - Reply Share
Considering the placement of wires attached by solder on both sides of the top board, it would be quite difficult to reach anything beneath it otherwise. I suppose it depends on what you're trying to achieve.
In any case, you might as well try to move it without desoldering if desoldering is going to be an issue. Make sure not to pull hard, though.
Liam Gow - Reply Share
I have a question... Will the motherboard you can get at the store here work it the newer controllers with built in headphone jack?
ETHREAL1 - Reply Share
I would expect not, I'm afraid. The motherboards will probably have different circuitry, even if the shapes are the same, which they may not be.
The position/mounting of the LB and RB buttons on the motherboard piece between the day-one/sans-jack and the newer 3.5mm jack (non-Slim) boards are completely different.
The older revision motherboard has the mountings inverted (pointing downwards to the south end-headset attachment port- of the controller) compared to the newer ones.
The newer ones have the circuit with the bumper buttons mounted pointing to the north end toward the bumpers on the top of the controller.
icho - Reply Share
Past 24 Hours: 8
Past 7 Days: 56
Past 30 Days: 277
All Time: 68,651
