Introduction
Go to step 1 ↓This guide shows a step-by-step procedure of replacing the Fan/heat Sink.
Tools
Slide the lock to the right, located slightly above the battery location.
While pulling the lock, pull the battery out, keeping it flat and parallel to the laptop so that it slides out easily.
Loosen the 2 Phillips 2.5x6 screws in the rectangular panel with a Phillips #1 screwdriver.
Gently remove the panel with a plastic opening tool.
Unscrew the three Phillips 2.5x6 screws in the L-shaped panel on the back with a Phillips #1 screwdriver.
Use a plastic opening tool to gently pry the panel free from the laptop.
Remove the 3 Phillips 2.5x5 screws (closest to the battery slot) and the 2 Phillips 2.5x6.5 screws with a Phillips #1 screwdriver.
Remove four Phillips PM2.5x3 screws in the battery bay, and remove ten Phillips PM2.5x6.5 screws on the base enclosure with a Phillips #1 screwdriver.
Disconnect the fan cable from the system board.
Loosen the four Phillips PM2.5×7.0 captive screws that secure the fan/heat sink assembly to the system board with a Phillips 0 screwdriver.
2 other people completed this guide.
