Xbox One Wireless Controller Faceplate Replacement
  1. Xbox One Wireless Controller Faceplate Replacement, Battery Pack: step 1, image 1 of 1
    • Remove the battery pack cover.
    • Remove batteries.
    Ask FixBot
  2. Xbox One Wireless Controller Faceplate Replacement, Side Handles: step 2, image 1 of 2 Xbox One Wireless Controller Faceplate Replacement, Side Handles: step 2, image 2 of 2
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
    Ask FixBot
  3. Xbox One Wireless Controller Faceplate Replacement, Screws: step 3, image 1 of 2 Xbox One Wireless Controller Faceplate Replacement, Screws: step 3, image 2 of 2
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
    Ask FixBot
  4. Xbox One Wireless Controller Faceplate Replacement, Backplate: step 4, image 1 of 1
    • Remove the backplate.
    Ask FixBot
  5. Xbox One Wireless Controller Faceplate Replacement, Faceplate: step 5, image 1 of 1
    • Remove the faceplate.
    Ask FixBot
91 other people completed this guide.
Tommy
2,011 Reputation
2 Guides authored
Cal Poly, Team 20-15, Maness Winter 2015 Member of Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 Members
54 Guides authored
11 Guide Comments
It was a good tutorial, but i have two plastic rings that stay after my instervention... Anyone knows where are-they ?
Matis Begot - Reply Share
laurito andrea12 - Reply Share
Note before starting. You need a T8 security bit (with a hole in the middle), not a standard T8 bit.
Fraser Currie - Reply Share
I took mine a part because it was looking dirty, gave it a good clean, putting it back together was easy but it wont work with the batteries anymore just the power core, there is nothing broken or cracked, any ideas?
Lee - Reply Share
Maybe you forced the battery contact on the wrong side of the case?
Alexandre Foley - Reply Share
Past 24 Hours: 9
Past 7 Days: 122
Past 30 Days: 350
All Time: 252,196
