Nikon Coolpix P100 Viewfinder Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
92
All Time:
1,712
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
This will show you how to open up the camera and replace the camera flash.
Tools
    1. Nikon Coolpix P100 Viewfinder Replacement, Nikon Coolpix P100  Motherboard Access: step 1, image 1 of 1
      • Turn the front of the camera toward you.
      Ask FixBot
    2. Nikon Coolpix P100 Viewfinder Replacement: step 2, image 1 of 3 Nikon Coolpix P100 Viewfinder Replacement: step 2, image 2 of 3 Nikon Coolpix P100 Viewfinder Replacement: step 2, image 3 of 3
      • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
      Ask FixBot
    3. Nikon Coolpix P100 Viewfinder Replacement: step 3, image 1 of 1
      • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
      Ask FixBot
    4. Nikon Coolpix P100 Viewfinder Replacement: step 4, image 1 of 1
      • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
      • Remove the screw
      Ask FixBot
    5. Nikon Coolpix P100 Viewfinder Replacement: step 5, image 1 of 1
      • Flip the camera upside down and remove the seven marked screws.
      Ask FixBot
    6. Nikon Coolpix P100 Viewfinder Replacement: step 6, image 1 of 2 Nikon Coolpix P100 Viewfinder Replacement: step 6, image 2 of 2
      • Turn the back of the camera toward you.
      • Lift the display panel and remove the two marked screws
      Ask FixBot
    7. Nikon Coolpix P100 Viewfinder Replacement: step 7, image 1 of 3 Nikon Coolpix P100 Viewfinder Replacement: step 7, image 2 of 3 Nikon Coolpix P100 Viewfinder Replacement: step 7, image 3 of 3
      • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
      Ask FixBot
    8. Nikon Coolpix P100 Viewfinder Replacement: step 8, image 1 of 1
      • Before fully opening the camera, identify the two marked ribbon cables
      • Properly detach the ribbons before proceeding
      Ask FixBot
    9. Nikon Coolpix P100 Viewfinder Replacement: step 9, image 1 of 1
      • Carefully open the camera.
      • Now you have partial access to the camera's motherboard.
      Ask FixBot
    10. Nikon Coolpix P100 Viewfinder Replacement: step 10, image 1 of 1
      • Remove the five indicated screws that are attached to the metal plate.
      Ask FixBot
    11. Nikon Coolpix P100 Viewfinder Replacement: step 11, image 1 of 1
      • Remove the hidden top screw that is attached to the metal plate.
      Ask FixBot
    12. Nikon Coolpix P100 Viewfinder Replacement: step 12, image 1 of 1
      • Use a plastic iFixit opening tool to carefully loosen the metal plate.
      • Remove the metal plate to access the camera's motherboard.
      Ask FixBot
    13. Nikon Coolpix P100 Viewfinder Replacement: step 13, image 1 of 1
      • Now you have access to the camera's motherboard
      Ask FixBot
    1. Nikon Coolpix P100 Viewfinder Replacement, Viewfinder: step 14, image 1 of 1
      • Remove the screw that is located on the left of the view finder.
      Ask FixBot
    2. Nikon Coolpix P100 Viewfinder Replacement: step 15, image 1 of 1
      • Carefully detach the two ribbon cables and detach the viewfinder.
      Ask FixBot
3 other people completed this guide.
Nghiem Ngo
339 Reputation
2 Guides authored
USF Tampa, Team 1-1, Tanski Winter 2015 Member of USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 92
All Time: 1,712
