iVIEW-754TPC Battery Replacement
Views: 3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
92
All Time:
2,984
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Introduction
Go to step 1 ↓
Is your device no longer holding a charge? Use this guide to replace a faulty or worn out battery.
Tools
    1. iVIEW-754TPC Battery Replacement, Rear Panel: step 1, image 1 of 3 iVIEW-754TPC Battery Replacement, Rear Panel: step 1, image 2 of 3 iVIEW-754TPC Battery Replacement, Rear Panel: step 1, image 3 of 3
      • Before disassembling your tablet, make sure it is powered off.
      • Use plastic opening tool to release the clips holding the device together. The clips will take a small amount of pressure to release. Once you have the plastic opening tool inserted, use a twisting action to release the clips. Start from bottom of device and work all the way around.
      Ask FixBot
    1. iVIEW-754TPC Battery Replacement, Remove Battery: step 2, image 1 of 3 iVIEW-754TPC Battery Replacement, Remove Battery: step 2, image 2 of 3 iVIEW-754TPC Battery Replacement, Remove Battery: step 2, image 3 of 3
      • Use flat side of the spudger to get under battery and use pressure to release from glue. Do this all the way around battery until it comes off.
      • At this point do not attempt to fully remove the battery as it is still attached to the logic board.
      Ask FixBot
    1. iVIEW-754TPC Battery Replacement, Desolder wires: step 3, image 1 of 3 iVIEW-754TPC Battery Replacement, Desolder wires: step 3, image 2 of 3 iVIEW-754TPC Battery Replacement, Desolder wires: step 3, image 3 of 3
      • Once battery is off, the wires will still be connected to motherboard. You will need to desolder the wires.
      • Using the soldering tool, use the heat to melt the connection. As you do this, pull on the wires with a tweezer until wires comes off.
      • To ease reassembly, take note of which wire goes to the negative and positive terminals.
      Ask FixBot
3 other people completed this guide.
calvin
188 Reputation
1 Guide authored
USF Tampa, Team 5-4, Brown Winter 2015 Member of USF Tampa, Team 5-4, Brown Winter 2015
USFT-BROWN-W15S5G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 92
All Time: 2,984
