Sirius Stiletto 2 LCD Display Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
93
All Time:
807
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replace your LCD display only as a last option. Since the LCD display uses a flexible flat cable(FFC), improperly inserting the cable may cause damage to your device.
Tools
    1. Sirius Stiletto 2 LCD Display Replacement, Battery: step 1, image 1 of 1
      • From the back of the device, slide the back panel downwards to unlock the panel.
      • Lift the panel up, exposing the battery.
      Ask FixBot
    2. Sirius Stiletto 2 LCD Display Replacement: step 2, image 1 of 2 Sirius Stiletto 2 LCD Display Replacement: step 2, image 2 of 2
      • Pinch the battery from both sides and lift the battery to remove it.
      Ask FixBot
    1. Sirius Stiletto 2 LCD Display Replacement, Front Cover: step 3, image 1 of 1
      • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
      • If needed, remove the sticker to see the screws
      Ask FixBot
    2. Sirius Stiletto 2 LCD Display Replacement: step 4, image 1 of 2 Sirius Stiletto 2 LCD Display Replacement: step 4, image 2 of 2
      • Start by using a plastic opening tool to loosen the front cover from the sides.
      • Work your way to the bottom of the cover then the top.
      • Carefully pry the front cover off.
      Ask FixBot
    1. Sirius Stiletto 2 LCD Display Replacement, LCD Display: step 5, image 1 of 1
      • Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
      Ask FixBot
    2. Sirius Stiletto 2 LCD Display Replacement: step 6, image 1 of 2 Sirius Stiletto 2 LCD Display Replacement: step 6, image 2 of 2
      • Carefully grip the screen and pull it away from the ribbon connector located on the motherboard.
      Ask FixBot
    3. Sirius Stiletto 2 LCD Display Replacement: step 7, image 1 of 1
      • LCD display (left).
      Ask FixBot
Benjamin Her
567 Reputation
5 Guides authored
USF Tampa, Team 6-6, Brown Winter 2015 Member of USF Tampa, Team 6-6, Brown Winter 2015
USFT-BROWN-W15S6G6
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 93
All Time: 807
