Xbox One S Hard Drive Assembly
  1. Xbox One S Hard Drive Assembly, Case: step 1, image 1 of 1
    • Flip the Xbox One S so that the bottom of the case is facing upward.
  2. Xbox One S Hard Drive Assembly: step 2, image 1 of 1
    • Begin by working at the case on the rear where the warranty sticker is located. Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place. Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
    • You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
    • It's possible that the clips may break when you remove the bottom from the case.
    • We recommend starting at the back where the warranty sticker is located. Pry along the rear edge until all clips are free. From there do each side. When three sides are free start at the end of the front opposite the sync button. Be cautious and take your time and all should separate without any damage.
  3. Xbox One S Hard Drive Assembly: step 3, image 1 of 1
    • Once all of the clips are opened, remove the bottom part of the case.
  4. Xbox One S Hard Drive Assembly: step 4, image 1 of 2 Xbox One S Hard Drive Assembly: step 4, image 2 of 2
    • Use a T10 Torx screwdriver to remove the six green 50 mm long screws from the metal case labeled F1 through F6.
  5. Xbox One S Hard Drive Assembly: step 5, image 1 of 2 Xbox One S Hard Drive Assembly: step 5, image 2 of 2
    • Gently separate the interior case from the white exterior case using the appropriate method.
    • Pry the white plastic sides outwards at the rear to separate from the plastic I/O shield
  6. Xbox One S Hard Drive Assembly, Interior Case Top Panel: step 6, image 1 of 1
    • Flip the interior case so it is fan side upward.
  7. Xbox One S Hard Drive Assembly: step 7, image 1 of 1
    • To access the hardware within the casing, you can pop and lift the top panel of the casing. It should come right off.
  8. Xbox One S Hard Drive Assembly, Hard Drive Assembly: step 8, image 1 of 2 Xbox One S Hard Drive Assembly, Hard Drive Assembly: step 8, image 2 of 2
    • To replace the hard drive, flip over the console and remove the two 10 mm T-10 Torx screws, C3 and C4, from the backside of the Xbox One S.
    • This will allow the plastic casing surrounding the hard drive to become detached from the rest of the console.
  9. Xbox One S Hard Drive Assembly: step 9, image 1 of 3 Xbox One S Hard Drive Assembly: step 9, image 2 of 3 Xbox One S Hard Drive Assembly: step 9, image 3 of 3
    • Gently disconnect the hard drive from the motherboard (at the two plastic connector bodies).
Victoria Law
976 Reputation
3 Guides authored
Cal Poly, Team S22-G3, Livingston Spring 2017 Member of Cal Poly, Team S22-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G3
4 Members
56 Guides authored
Past 24 Hours: 3
Past 7 Days: 51
Past 30 Days: 219
All Time: 10,646
