Insert the plastic opening tool into the gap between the bottom of the case and the grated top side. Then find the clips in between that hold the case in place.
Use the opening tool to pop the clips out. The best method is to pry the black case away from the bottom.
You will hear clicking sounds when you are prying the case open. It may be fairly difficult to remove the bottom.
It's possible that the clips may break when you remove the bottom from the case.
We recommend starting at one corner and sliding the prying tool along the edges of the Xbox One S. Once the first few clips are opened you can lift the cover up to find the remaining clips.
Insert a pry tool gently between the top cover and metal casing on both sides to prepare the cover for removal.
This step is necessary because you need to pry interior rivets away from the exterior case. The interior rivets that that hold the case in place are highlighted in the last image. After you gently pry in the areas demonstrated, the side panel of the Xbox One S will be able to come off of the rest of the casing. (See images in Step
