Replacing Creative Zen X-Fi Battery
Views: 9.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
29
Past 30 Days:
169
All Time:
9,186
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
The battery stores the power that enables the device to run.
Tools
  • Soldering Iron
    $249.95
    4.6
  • Spudger
    4.9
    1. Replacing Creative Zen X-Fi Battery, Detaching Front Case: step 1, image 1 of 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: step 1, image 2 of 3 Replacing Creative Zen X-Fi Battery, Detaching Front Case: step 1, image 3 of 3
      • Using a spudger, wedge the tip between the front and back case to pry them apart.
      • Be careful to not apply excessive force since there are six fasteners on the screen's side that holds the cases firmly together.
      Ask FixBot
    1. Replacing Creative Zen X-Fi Battery, Rubber Button Cover: step 2, image 1 of 1
      • The black rubber button pad can be removed by simply picking it up.
      Ask FixBot
    1. Replacing Creative Zen X-Fi Battery, Button Input Chip Part 1: step 3, image 1 of 1
      • Flip the LCD screen off the midsection plate to gain access to the space around the input button chip.
      Ask FixBot
    2. Replacing Creative Zen X-Fi Battery, Button Input Chip: step 4, image 1 of 1
      • Using a spudger, pry off the button input chip from the mid-section of the device. To gain best leverage, start at the bottom right corner and level your way up the side of the chip.
      • Be aware that the button input chip is glued to the mid-section, so some extra force may be required.
      Ask FixBot
    1. Replacing Creative Zen X-Fi Battery, Access Midsection Plate: step 5, image 1 of 1
      • Lift open the LCD screen and button input chip to access the entire midsection plate.
      Ask FixBot
    2. Replacing Creative Zen X-Fi Battery, Unscrew below Button Chip: step 6, image 1 of 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the button input chip.
      Ask FixBot
    3. Replacing Creative Zen X-Fi Battery, Unscrew below LCD Screen: step 7, image 1 of 1
      • Use a Phillips Head screwdriver to unscrew the three 3/16 inch screws that were underneath the LCD screen.
      Ask FixBot
    1. Replacing Creative Zen X-Fi Battery, Separating the Battery: step 8, image 1 of 1
      • Use a spudger to pry the battery from the midsection plate.
      • There is adhesive glue underneath the battery, so additional force might be required to separate the battery.
      Ask FixBot
    2. Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: step 9, image 1 of 2 Replacing Creative Zen X-Fi Battery, Disconnecting Power Supply: step 9, image 2 of 2
      • Locate the soldering joint connecting the battery wires to the power supply, marked by the letters "PS" on the motherboard.
      • Hold the battery wires in place so that access to the soldering joints is not blocked.
      • When using a soldering iron, keep your hands and fingers as far as possible from the iron's tip to avoid burning your skin.
      • Using a soldering iron, melt the solder connecting the red wire to the motherboard. Do the same action to the black wire.
      Ask FixBot
5 other people completed this guide.
Westley Courchene
3,410 Reputation
14 Guides authored
2 Guide Comments
very clear pictures!
John - Reply Share
разбирать нужно со стороны противоположной гнезда наушников!!! поломал так же как и на фото все защелки со стороны кнопок(
Cooper21 - Reply Share
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 169
All Time: 9,186
