You can pop the connector up to remove the ribbon easily
Ribbon Cable
Desolder the 4 wires on each side, these control the vibrations and the RT LT
Desolder the 4 pins holding the pins in on the left analog stick.
Desolder the 4 pins holding the button in on the right analog stick.
First, desolder the left analog stick.
Next, desolder the 6 pins for the right analog stick.
Desolder the left analog stick from the controller.
Desolder the right analog stick from the controller.
If you are having trouble desoldering here are the two things you can do to solve.
You can use a screw driver to open the resistors and then remove them from the board allowing access to the ground pins
Now using snips you can cut the pins and then use a soldering iron to both sides and remove the cut pin gently with pliers
