Xbox One Elite Controller (Model 1698) Disassembly
  1. Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: step 1, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Show me the Screws!: step 1, image 2 of 2
    • You can remove the side panels with a pry tool.
    • You don't need to remove the rubber. The rubber on this controller was already bad
  2. Xbox One Elite Controller (Model 1698) Disassembly, Removing the back panel screws: step 2, image 1 of 1
    • Remove the 5 Torx Security Bit (TR9) screws
    all the T8 screws on my controller have a clear filling in them, WTF?!?!?
    Patrick Henry - Reply
    all my T8 screws have a clear filling in them, WTF?!?!?!
    I've never seen that, I can't advise much other than scrapping it out with an xacto knife
    EasyAsABC123 - Reply
    My screws have a tiny metal pin in the center. Looks like I need a TR8 bit, not a T8. This might be what you are mistaking for a clear filling.
    Steve McGinn - Reply
    Thanks it might be TR8 i’ll update the guide
    While a TR8 will work, they’re actually TR9 screws on mine (Model 1698, X912908-004).
    Daniel - Reply
    @isbelldl thanks, updated to specify TR9
    TORX TR8 worked form the ifixit kit
    KRISTIAN KALLAWAY - Reply
    My anolog stick is lagging on my elite 1 controller. Can I remove a anolog module from a normal xbox 1 controller and then put into the elite 1 controller would it be compatible. I have all the soldering irons and stuff. It's only that I dont have any money and wanted to no if thay would work . Thanks guy appreciate your time kris
    kriswadd@hotmail.com - Reply
  3. Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: step 3, image 1 of 3 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: step 3, image 2 of 3 Xbox One Elite Controller (Model 1698) Disassembly, Popping that back panel off: step 3, image 3 of 3
    • Pry the panel next to the 3.5mm port
    • Be careful to not rip the ribbon shown in the next step
  4. Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: step 4, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Warning Carefully remove the ribbon: step 4, image 2 of 2
    • Be careful to not rip the ribbon cable
    • You can pop the connector up to remove the ribbon easily
    • Ribbon Cable
    My connector did not look like this and popping it up broke it
    Amarokstar - Reply
    please post a picture of the connector so we can update this, you also might have a newer revision of the motherboard
    Is there any way to replace that connector bar or maybe an alternative to keeping the contacts down on the ribbon if it’s broken?
    Joe - Reply
    @joe you can try tape, or even hot glue (easy to remove with rubbing alcohol), that might hold it down. I wasn’t able to find the connector but i’m sure if you count the number of pins and measure it you’d be able to locate a replacement connector on something like mouser.
  5. Xbox One Elite Controller (Model 1698) Disassembly, Screws on controller motherboard: step 5, image 1 of 1
    • Remove the 2 Torx (T6) screws
  6. Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: step 6, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Desolder wires from motherboard: step 6, image 2 of 2
    • Desolder the 4 wires on each side, these control the vibrations and the RT LT
    If you are just replacing the main power board there is no need to desolder at this point. The main power board can be removed with the controller board still in place.
    Malc Foy - Reply
  7. Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: step 7, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Remove the motherboard: step 7, image 2 of 2
    • Pull up from the "top" side of the controller on the sister board.
    Hi,
    I would like to know if I could get from you a Motherboard . In case you don' t have it, where could I find one?
    Thank you
    Alejandro Expósito - Reply
    Hi, I have 2 not working controllers (both 1698 and 1708). The 1708 broke the bumper switch, I manage to fix it but as always, postponed. So, can I either swap Xbox One Elite comtroller (1698) into Xbox One (1708) shell/housing or vice versa??
    Or can I mix both motherboard together so I can make one of them working?
    Fitifazrul Rahman - Reply
    It might work…it might damage one of the boards but probably wouldn’t
    EasyAsABC123 -
    I would like to buy a motherboard, can you please stock some up?
    davi_t - Reply
    I don’t work for ifixit, I don’t know if they see comments on a private made guide.
    EasyAsABC123 -
    I decided to toss all this stuff in the trash at this point as I am not going to spend +$50 on equipment and replacement parts to fix a $60 controller. But thanks for the educational manual all the same.
  8. Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: step 8, image 1 of 3 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: step 8, image 2 of 3 Xbox One Elite Controller (Model 1698) Disassembly, Remove the Home Button Cover: step 8, image 3 of 3
    • Be Careful to not lose the sync button
    • Pry the middle section up from the home button side.
    • This will also remove the LB and RB which is a single part
  9. Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: step 9, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Remove the controller daughterboard: step 9, image 2 of 2
    • Unscrew the 6 Torx (T6) screws
    On the 2nd picture: the D-pad dome switches are covered by a clear plastic film: is possible to remove it/reattach that plastic film? I believe there might be something stuck underneath the dome switches that’s interfering with the d-pad buttons working reliably/consistently. I know I could just replace the daughterboard, but I’m trying to avoid doing that if I can just clean it some how/find a way around it
    [deleted] - Reply
    This is just tacom tape :), feel free to buy more and replace
    Hi anyone know of where to find that rubber thing that goes on lb/rb trigger?
    kostas kazlauskas - Reply
    rubber thing? You mean the lb and rb part itself? or the home button section?
    EasyAsABC123 -
    The lb/rb white rubber behind the button supoort rubber i dont know how its called
    kostas kazlauskas -
  10. Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: step 10, image 1 of 2 Xbox One Elite Controller (Model 1698) Disassembly, Xbox One Elite Controller (Model 1698) Disassembly: step 10, image 2 of 2
    • Now you can remove the buttons themselves.
    how Is this considered difficult took me 15 mins
    TwiZ Faded - Reply
    Cool it, no need to be like that. You're the one using their tutorial, how about you just say thanks
    Matthew R Dunham -
    Same, also if anyone’s wondering the stick drift I had was just caused by hair and gunk in the mechanisms of the controller, same with the d pad not working, just by simply taking the controller apart and fully cleaning it and bending a few things back into place all issues are gone
    REESES Peanut Butter Cups -
    Rip my ribbon cable
    pedroferraz - Reply
40 other people completed this guide.
EasyAsABC123
2,407 Reputation
5 Guides authored
14 Comments
Is there any way I could just do step 8, removing the Home cover? I simply need to fix my USB port so i dont really wanna take it completely apart just for that.
jones_8515 - Reply
Desoldering the rumble motors isn't necessary, nor is removing the first motherboard. Once you get that back panel off, you're golden.
J'Anthony Joseph -
Ya hi i opened my controller and right away i don’t see ether bolt in both handles. 4 i believe to top two bottom.
Suggestions please.
Craig Amyotte - Reply
I found using a TQ5 for the 2 motherboard screws worked the best on my controller not a T6
Mat - Reply
Thanks for the info
EasyAsABC123 -
Awesome guide. After taking mine apart it won’t turn on without plugging it in first. When I plug it in it turns on and I can unplug it and use it like normal but the Xbox button won’t turn the controller on by itself. Have you ever encountered that?
Tim Hogg - Reply
I have never run into this, that is definitely an unusual problem
EasyAsABC123 -
how to glue this sh*ty ribbon? mine also badly removed by itself
senoritavikki - Reply
You probably would want to count the wires in the ribbon and then buy a replacement
EasyAsABC123 -
Anyone have a solution for the incredibly uncommon problem where: maximum input to left analog ↑ forward and depressed (sprint/tactical sprint for Modern Warfare) will be read as a pull or incredibly rapid pulls on the right trigger? Have an elite II that I needed to send in cause of another left stick issue (ridiculous) an I pulled out my old elite 1 that worked perfectly before but suddenly I have this going on. its not a mapping issue and it will stop if I change to another stick attachment but after a minute or so will start again. Change stick, start again, etc. Ready to leave the soldering iron over the middle of the device and go for a long walk…
Jack Kessler - Reply
Unless you are replacing the motherboard, you probably don’t have to de-solder the wires to the rumble motors or triggers. I carefully pulled the trigger wires out of their channels and had plenty of room to move the motherboard out of the way to pull the daughterboard. This allows a lot of replacement without having to solder anything. Note that it helps a lot to tape the rumble motors into their slots since they are just sitting in there and may fall out while you are trying to manipulate the daughterboard.
Scott Gartner - Reply
Mine the right bumper broke a clip or something on the outside part n it will drop or move n get stuck or make the trigger stuck n not work drives me inside is there a fast easy way to say remove it without taking it all apart don't don't do that n I'll map it to the lower ones or something? And do these have a warranty some say it dose jw thanks to any who help or reply to this in advance
Dman d - Reply
I need to fix (or replace it if I can't fix it, not sure what's wrong with it yet) The LB button. Do I need to remove the mother board?
maxmattt - Reply
how would i fix drift on the joysticks
Statesidekarma - Reply
Past 24 Hours: 18
Past 7 Days: 125
Past 30 Days: 466
All Time: 94,080
