Xbox One Drive PCB Replacement
  1. Xbox One Drive PCB Replacement, Remove the tape: step 1, image 1 of 3 Xbox One Drive PCB Replacement, Remove the tape: step 1, image 2 of 3 Xbox One Drive PCB Replacement, Remove the tape: step 1, image 3 of 3
    • First of all, remove the sticker/tape from the back of the drive to reveal the 2 other screws. You can do this with your fingers, it could take a little force, but not to much.
  2. Xbox One Drive PCB Replacement, Remove the screws and back cover: step 2, image 1 of 3 Xbox One Drive PCB Replacement, Remove the screws and back cover: step 2, image 2 of 3 Xbox One Drive PCB Replacement, Remove the screws and back cover: step 2, image 3 of 3
    • Remove the 4 PH1 screws.
    • Lift up the back cover and remove it. It should not take any force and should come off easily. I lifted it up at the left side.
  3. Xbox One Drive PCB Replacement, Remove the ribbon cables: step 3, image 1 of 3 Xbox One Drive PCB Replacement, Remove the ribbon cables: step 3, image 2 of 3 Xbox One Drive PCB Replacement, Remove the ribbon cables: step 3, image 3 of 3
    • Do NOT remove the ribbon cables yet, make sure you opened up the ZIF connector first and then remove the ribbon cables. Otherwise you could damage the PCB.
    • Open up all the 3 ZIF connectors with your finger nails or with an plastic opening tool carefully.
    • Then remove the 3 ribbon cables from their sockets.
  4. Xbox One Drive PCB Replacement, Desolder the cables: step 4, image 1 of 3 Xbox One Drive PCB Replacement, Desolder the cables: step 4, image 2 of 3 Xbox One Drive PCB Replacement, Desolder the cables: step 4, image 3 of 3
    • You will see an red and an black cable soldered to the PCB.
    • Now get your solder iron ready to desolder the 2 cables. Heat and melt the solder, with your other hand hold the tweezer. When the solder is melting, remove the cable with your tweezer to get the cable out.
    • It's recommended you use desoldering wick, so you can put some fresh new solder on the pads. Recommended but not required.
    • Now it should look like the last photo.
  5. Xbox One Drive PCB Replacement, Remove the screws: step 5, image 1 of 1
    • Remove the tiny 3 PH1 screws from the PCB.
  6. Xbox One Drive PCB Replacement, Remove the PCB from the drive: step 6, image 1 of 3 Xbox One Drive PCB Replacement, Remove the PCB from the drive: step 6, image 2 of 3 Xbox One Drive PCB Replacement, Remove the PCB from the drive: step 6, image 3 of 3
    • Hold the PCB and move it up. You should notice that PCB will come loose from the drive.
    • Now hold in the middle and move it upward a little and the back to yourself. Be aware that it will need a little force (especially from the right side, as a clip is holding it down), but it should come off easily.
    • That's it! You got the PCB out!
  7. Xbox One Drive PCB Replacement, Installing the new PCB: step 7, image 1 of 2 Xbox One Drive PCB Replacement, Installing the new PCB: step 7, image 2 of 2
    • When installing the new PCB, look out for the spots as shown in Photo 1 (red circles). When you follow photo 1 and tight it with screws, you could break the PCB ! So do the opposite of Photo 1!
    • Photo 2 shows correctly how the PCB need to be seated. As you can see in the blue circles.
koppie007
13,110 Reputation
9 Guides authored
Protectors Of The Game Systems Member of Protectors Of The Game Systems
Community
4 Members
27 Guides authored
Past 24 Hours: 6
Past 7 Days: 65
Past 30 Days: 234
All Time: 21,063
