Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement
    1. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: step 1, image 1 of 3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: step 1, image 2 of 3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement, Main PCB Board: step 1, image 3 of 3
      • First, detach the lens by pressing and holding the release button highlighted in the picture.
      • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
      • Finally, when the camera stops rotating, pull the lens away from the camera.
      Ask FixBot
    2. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 2, image 1 of 2 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 2, image 2 of 2
      • Remove the four 5.5mm JIS #000 screws for the lens mount ring (silver ring).
      • Remove the two 4mm JIS #000 screws mounting the main board connector.
      • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
      Ask FixBot
    3. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 3, image 1 of 2 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 3, image 2 of 2
      • Using a spudger, pull the connector loose from the barrel switch ring assembly.
      • Set barrel switch ring assembly to the side.
      Ask FixBot
    4. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 4, image 1 of 2 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 4, image 2 of 2
      • This step involves handling sensitive electronics. Avoid static discharge.
      • Using a spudger, pull the five connectors out of their housing.
      • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
      Ask FixBot
    5. Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 5, image 1 of 3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 5, image 2 of 3 Canon EF-S 18-135mm f/3.5-5.6 IS STM Main Board Replacement: step 5, image 3 of 3
      • Remove the two 4mm JIS #000 main board mounting screws.
      • Remove the main board from the lens with your hand.
      • The main board is now successfully removed from the lens.
      Ask FixBot
4 other people completed this guide.
Paul
1,005 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 73
All Time: 3,590
