Xbox Hard Drive Replacement
  1. Xbox Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Make sure your Xbox is safely unplugged and is laying on a flat, stable surface.
  2. Xbox Hard Drive Replacement: step 2, image 1 of 1
    • Turn the Xbox over to reveal the four rubber feet.
    • Use a metal spudger to pry off the four rubber feet.
  3. Xbox Hard Drive Replacement: step 3, image 1 of 2 Xbox Hard Drive Replacement: step 3, image 2 of 2
    • There are 2 more screws hidden under the two labels on the bottom of the case.
    • You can either remove the labels or simply feel for the screw holes through the labels and then cut or punch a hole through them.
    • These labels are "Tamper Resistant" and will usually reveal a checkerboard pattern when removed. To reduce the likelihood of this happening, use a hair dryer or heat gun to warm the labels and soften the adhesive first. The pattern may still appear, however it won't be as bad.
  4. Xbox Hard Drive Replacement: step 4, image 1 of 1
    • Remove the six T20 Torx screws securing the top cover to the bottom cover.
  5. Xbox Hard Drive Replacement: step 5, image 1 of 2 Xbox Hard Drive Replacement: step 5, image 2 of 2
    • Wedge a metal spudger and carefully pry upwards to slightly separate the top and bottom covers.
    • Flip the Xbox right side up.
    • Hold the sides and lift the Xbox slightly off the bench. A gentle shake of the unit should see the top cover separate from the rest of the unit quite easily.
    • Placing the Xbox on your lap while separating the top and bottom covers may make the process easier.
  6. Xbox Hard Drive Replacement: step 6, image 1 of 2 Xbox Hard Drive Replacement: step 6, image 2 of 2
    • Once the bottom and top shells are no longer attached, carefully turn the Xbox right-side-up, lift and remove the top cover.
  7. Xbox Hard Drive Replacement: step 7, image 1 of 2 Xbox Hard Drive Replacement: step 7, image 2 of 2
    • Remove the three 3 mm T10 screws securing the hard drive to the Xbox.
    • There is one screw on the rear left side of the hard drive that is only visible when the IDE ribbon cable is lifted up. The other two are at the front right and left sides of the hard drive.
    • The screw on the lower left corner of the disk drive is not in the hole that it appears to be in, but rather just closer to the corner.
  8. Xbox Hard Drive Replacement: step 8, image 1 of 2 Xbox Hard Drive Replacement: step 8, image 2 of 2
    • Free the hard drive power cable from the carrier for sufficient slack to lift the hard drive out.
    • Lift the plastic hard drive carrier out of the Xbox case.
  9. Xbox Hard Drive Replacement: step 9, image 1 of 3 Xbox Hard Drive Replacement: step 9, image 2 of 3 Xbox Hard Drive Replacement: step 9, image 3 of 3
    • Remove the four 3.4 mm T15 Torx screws from the plastic hard drive carrier (two screws per side).
    • Carefully remove the hard drive from the plastic carrier. Gentle rocking will see the hard drive come out quite easily.
  10. Xbox Hard Drive Replacement: step 10, image 1 of 2 Xbox Hard Drive Replacement: step 10, image 2 of 2
    • Pull both the hard drive data ribbon cable and the power cable straight up from the hard drive.
    • They may be firmly seated, so be careful trying to remove them. DO NOT pull the wires as you may damage the cable assembly.
rmarstel
5,704 Reputation
5 Guides authored
Cal Poly, Team 18-2, Maness Fall 2009 Member of Cal Poly, Team 18-2, Maness Fall 2009
CPSU-MANESS-F09S18G2
3 Members
24 Guides authored
Past 24 Hours: 12
Past 7 Days: 76
Past 30 Days: 323
All Time: 68,712
