Shop the Holiday Gift Guide
Xbox Duke Controller Face Buttons Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
29
Past 30 Days:
74
All Time:
683
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
If the face buttons on the Xbox Duke Controller aren't working properly, sticking when you press them, not registering input, or delaying the input, use this guide to replace them.
Before using this guide, check to see if there is dirt or debris that is interfering with the buttons. Spraying a small amount of contact cleaner into the button can potentially fix the problem. Otherwise, the problem may lie in the silicone pads or the double-sided graphite tape that contacts the motherboard.
Before beginning, make sure to disconnect your Duke controller from the Xbox or any other console it may be plugged into.
Tools
    1. Xbox Duke Controller Face Buttons Replacement, Face Plate: step 1, image 1 of 3 Xbox Duke Controller Face Buttons Replacement, Face Plate: step 1, image 2 of 3 Xbox Duke Controller Face Buttons Replacement, Face Plate: step 1, image 3 of 3
      • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
      • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
      Ask FixBot
    2. Xbox Duke Controller Face Buttons Replacement: step 2, image 1 of 3 Xbox Duke Controller Face Buttons Replacement: step 2, image 2 of 3 Xbox Duke Controller Face Buttons Replacement: step 2, image 3 of 3
      • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
      Ask FixBot
    1. Xbox Duke Controller Face Buttons Replacement, Face Buttons: step 3, image 1 of 3 Xbox Duke Controller Face Buttons Replacement, Face Buttons: step 3, image 2 of 3 Xbox Duke Controller Face Buttons Replacement, Face Buttons: step 3, image 3 of 3
      • Remove the silicone pads and pull out the directional pad assembly.
      Ask FixBot
    2. Xbox Duke Controller Face Buttons Replacement: step 4, image 1 of 3 Xbox Duke Controller Face Buttons Replacement: step 4, image 2 of 3 Xbox Duke Controller Face Buttons Replacement: step 4, image 3 of 3
      • Using a plastic opening tool, remove the plastic plate from the bottom of the directional pad assembly.
      • Pull out the silicone pad.
      Ask FixBot
    3. Xbox Duke Controller Face Buttons Replacement: step 5, image 1 of 2 Xbox Duke Controller Face Buttons Replacement: step 5, image 2 of 2
      • Remove the silicone pads from the top plate of the controller and remove all of the face buttons.
      • To replace the buttons, line them up with the grooves in the top plate.
      Ask FixBot
Author
with
Anthony Casino
678 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 29
Past 30 Days: 74
All Time: 683
