Shop the Holiday Gift Guide
Xbox Duke Controller 6-Pin Cable Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
29
Past 30 Days:
114
All Time:
1,297
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If your Xbox Duke Controller isn't registering input of any kind or the console doesn't recognize that the controller is plugged in, use this guide to replace the 6-pin cable connected to the controller.
Before using this guide, check to see if the port on the Xbox console is damaged or needs to be cleaned. Then, check the end of the 6-pin cable to see if the connector itself is damaged or dirty. A small amount of contact cleaner will remove any dirt or debris within the port. If the cable or port show no visible signs of damage, then the Duke will need to be taken apart to disconnect the cable from the motherboard.
Follow the potentiometer replacement guide up to Step 9 to access the motherboard.
Tools
    1. Xbox Duke Controller 6-Pin Cable Replacement, Face Plate: step 1, image 1 of 3 Xbox Duke Controller 6-Pin Cable Replacement, Face Plate: step 1, image 2 of 3 Xbox Duke Controller 6-Pin Cable Replacement, Face Plate: step 1, image 3 of 3
      • Remove the seven black 8 mm screws holding the two halves of the Duke together using a Phillips #1 screwdriver.
      • To reach the deeply set screws, use a longer screw driver or a 4.0 socket bit in addition to the PH1 bit.
      Ask FixBot
    2. Xbox Duke Controller 6-Pin Cable Replacement: step 2, image 1 of 3 Xbox Duke Controller 6-Pin Cable Replacement: step 2, image 2 of 3 Xbox Duke Controller 6-Pin Cable Replacement: step 2, image 3 of 3
      • Remove the two halves of the Duke, placing the top plate face-down so the buttons don't fall out.
      Ask FixBot
    1. Xbox Duke Controller 6-Pin Cable Replacement, Potentiometer: step 3, image 1 of 2 Xbox Duke Controller 6-Pin Cable Replacement, Potentiometer: step 3, image 2 of 2
      • Remove the stick caps from the potentiometers.
      Ask FixBot
    2. Xbox Duke Controller 6-Pin Cable Replacement: step 4, image 1 of 2 Xbox Duke Controller 6-Pin Cable Replacement: step 4, image 2 of 2
      • Disconnect the connectors attaching the rumble motors to the motherboard using a pair of tweezers.
      • Be gentle when slipping the tweezers underneath the flaps of the connectors; they are fragile and can snap.
      Ask FixBot
    3. Xbox Duke Controller 6-Pin Cable Replacement: step 5, image 1 of 2 Xbox Duke Controller 6-Pin Cable Replacement: step 5, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the four yellow 8 mm screws holding the motherboard to the bottom half of the controller.
      Ask FixBot
    4. Xbox Duke Controller 6-Pin Cable Replacement: step 6, image 1 of 2 Xbox Duke Controller 6-Pin Cable Replacement: step 6, image 2 of 2
      • Remove the motherboard from the bottom half of the controller.
      Ask FixBot
    5. Xbox Duke Controller 6-Pin Cable Replacement: step 7, image 1 of 3 Xbox Duke Controller 6-Pin Cable Replacement: step 7, image 2 of 3 Xbox Duke Controller 6-Pin Cable Replacement: step 7, image 3 of 3
      • Desolder the connector pins holding the left trigger assembly in place.
      • Remove the trigger assembly by pushing on the black connectors that hold them to the motherboard.
      Ask FixBot
    6. Xbox Duke Controller 6-Pin Cable Replacement: step 8, image 1 of 1
      • Desolder all of the connector pins holding the potentiometer in place.
      • Pull out the potentiometers and solder the new ones into place.
      Ask FixBot
    1. Xbox Duke Controller 6-Pin Cable Replacement, 6-Pin Cable: step 9, image 1 of 3 Xbox Duke Controller 6-Pin Cable Replacement, 6-Pin Cable: step 9, image 2 of 3 Xbox Duke Controller 6-Pin Cable Replacement, 6-Pin Cable: step 9, image 3 of 3
      • Disconnect the cable from the memory card slot, sliding the black plastic holder out of the slot.
      • Remove the plastic piece from the cable.
      Ask FixBot
    2. Xbox Duke Controller 6-Pin Cable Replacement: step 10, image 1 of 2 Xbox Duke Controller 6-Pin Cable Replacement: step 10, image 2 of 2
      • Remove the memory card slot by sliding it away from the motherboard.
      Ask FixBot
    3. Xbox Duke Controller 6-Pin Cable Replacement: step 11, image 1 of 2 Xbox Duke Controller 6-Pin Cable Replacement: step 11, image 2 of 2
      • Desolder the pins holding the cable in place, then pull the cable away from the motherboard.
      • Solder the new cable into the motherboard.
      Ask FixBot
2 other people completed this guide.
Author
with
Anthony Casino
678 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 29
Past 30 Days: 114
All Time: 1,297
