Up to 20% off select tools
Xbox Controller S Buttons Replacement Guide
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
32
Past 30 Days:
169
All Time:
1,010
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
Introduction
Go to step 1 ↓
This guide will help you replace your Xbox Controller's buttons and D-pad in case they break or need cleaning.
    1. Xbox Controller S Buttons Replacement Guide, Backplate: step 1, image 1 of 2 Xbox Controller S Buttons Replacement Guide, Backplate: step 1, image 2 of 2
      • Remove the six visible 8mm Phillips screws with a #1 Phillips screwdriver.
      Ask FixBot
    2. Xbox Controller S Buttons Replacement Guide: step 2, image 1 of 2 Xbox Controller S Buttons Replacement Guide: step 2, image 2 of 2
      • Peel back the barcode sticker to reveal the seventh Phillips screw and remove it.
      Ask FixBot
    3. Xbox Controller S Buttons Replacement Guide: step 3, image 1 of 3 Xbox Controller S Buttons Replacement Guide: step 3, image 2 of 3 Xbox Controller S Buttons Replacement Guide: step 3, image 3 of 3
      • Carefully lift the backplate off of the controller.
      • Make sure to hold the frontplate to prevent the buttons from falling out.
      Ask FixBot
    4. Xbox Controller S Buttons Replacement Guide, Vibration Motors: step 4, image 1 of 3 Xbox Controller S Buttons Replacement Guide, Vibration Motors: step 4, image 2 of 3 Xbox Controller S Buttons Replacement Guide, Vibration Motors: step 4, image 3 of 3
      • Unplug the two vibration motors and lift them out of the case, being sure not to pull on the wires.
      Ask FixBot
    5. Xbox Controller S Buttons Replacement Guide, Logic Board: step 5, image 1 of 2 Xbox Controller S Buttons Replacement Guide, Logic Board: step 5, image 2 of 2
      • Lift the logic board out of the controller.
      Ask FixBot
    6. Xbox Controller S Buttons Replacement Guide, Rubber Pads: step 6, image 1 of 3 Xbox Controller S Buttons Replacement Guide, Rubber Pads: step 6, image 2 of 3 Xbox Controller S Buttons Replacement Guide, Rubber Pads: step 6, image 3 of 3
      • Remove the rubber pads.
      Ask FixBot
    7. Xbox Controller S Buttons Replacement Guide, Buttons: step 7, image 1 of 3 Xbox Controller S Buttons Replacement Guide, Buttons: step 7, image 2 of 3 Xbox Controller S Buttons Replacement Guide, Buttons: step 7, image 3 of 3
      • Remove the A, B, X, Y, White, and Black buttons with a pair of tweezers.
      • Remove the Back and Start buttons.
      • When putting the buttons back in, make sure to align the notches with the case.
      Ask FixBot
    8. Xbox Controller S Buttons Replacement Guide, D-Pad: step 8, image 1 of 3 Xbox Controller S Buttons Replacement Guide, D-Pad: step 8, image 2 of 3 Xbox Controller S Buttons Replacement Guide, D-Pad: step 8, image 3 of 3
      • Unscrew the the two 7mm Phillips screws.
      • Separate the D-pad by pushing the two clips in with a pair of tweezers.
      Ask FixBot
    9. Xbox Controller S Buttons Replacement Guide: step 9, image 1 of 1
      • Separate the two halves of the D-pad.
      • The front half of the D-pad will fall when you take the back half out, be sure to catch it.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order, being careful to line everything back up.
Author
with
burntpizza
199 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 32
Past 30 Days: 169
All Time: 1,010
