Xbox 360 Wireless Controller Triggers Replacement
  1. Xbox 360 Wireless Controller Triggers Replacement, Battery: step 1, image 1 of 2 Xbox 360 Wireless Controller Triggers Replacement, Battery: step 1, image 2 of 2
    • Depress the battery release button on the top of the controller.
    • Remove the battery holder from the controller.
    • The standard option for Xbox 360 Wireless Controllers Battery Packs is AA batteries. A rechargeable battery is also available, but both battery options are removed from the controller in the same way.
  2. Xbox 360 Wireless Controller Triggers Replacement, Rear Case: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to peel the barcode sticker from the battery compartment.
  3. Xbox 360 Wireless Controller Triggers Replacement: step 3, image 1 of 1
    • Remove the seven 9.3 mm T8 Security Torx screws securing the rear case to the front case.
  4. Xbox 360 Wireless Controller Triggers Replacement: step 4, image 1 of 2 Xbox 360 Wireless Controller Triggers Replacement: step 4, image 2 of 2
    Spudger
    $2.99
    Buy
    • Insert a Spudger between the front and rear cases along the left edge of the controller.
    • Rotate the spudger toward the front of the controller, prying the two cases apart.
  5. Xbox 360 Wireless Controller Triggers Replacement: step 5, image 1 of 2 Xbox 360 Wireless Controller Triggers Replacement: step 5, image 2 of 2
    • Insert a spudger between the front and rear cases, near the headphone jack.
    • Rotate the spudger toward the front of the controller to pry the two cases apart.
  6. Xbox 360 Wireless Controller Triggers Replacement: step 6, image 1 of 2 Xbox 360 Wireless Controller Triggers Replacement: step 6, image 2 of 2
    • Grasp the controller by the battery compartment and the headphone jack.
    • Lift the battery compartment away from the headphone jack, separating the rear case from the front case and logic board.
    • The battery contact springs are held in place by slots in the battery housing in the rear case. Be sure to realign them properly during reassembly.
  7. Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: step 7, image 1 of 2 Xbox 360 Wireless Controller Triggers Replacement, Vibration Motors: step 7, image 2 of 2
    • Use the flat end of a spudger to remove the vibration motor cable, moving it upward from its socket on the logic board.
    • Lift the vibration motor out of the front case.
  8. Xbox 360 Wireless Controller Triggers Replacement: step 8, image 1 of 2 Xbox 360 Wireless Controller Triggers Replacement: step 8, image 2 of 2
    • Remove the vibration motor from the other side of the controller using the same method previously described.
    • The left motor has significantly more counterweight than the right motor.
  9. Xbox 360 Wireless Controller Triggers Replacement, Logic Board: step 9, image 1 of 2 Xbox 360 Wireless Controller Triggers Replacement, Logic Board: step 9, image 2 of 2
    • Lifting from the headphone jack and power plug, remove the logic board from the front case.
  10. Xbox 360 Wireless Controller Triggers Replacement, Triggers: step 10, image 1 of 3 Xbox 360 Wireless Controller Triggers Replacement, Triggers: step 10, image 2 of 3 Xbox 360 Wireless Controller Triggers Replacement, Triggers: step 10, image 3 of 3
    • Using your thumb and forefinger, push the left trigger toward the right side of the controller. Simultaneously push the trigger control arm in the opposite direction.
    • The trigger has a peg that fits into a slot in the trigger arm. Be sure to push far enough so that the peg clears the slot.
    • Push the trigger arm down downwards.
  11. Xbox 360 Wireless Controller Triggers Replacement: step 11, image 1 of 3 Xbox 360 Wireless Controller Triggers Replacement: step 11, image 2 of 3 Xbox 360 Wireless Controller Triggers Replacement: step 11, image 3 of 3
    • Insert the edge of a spudger in between the trigger and the trigger assembly near the left edge. Pry the housing away from the catch on the trigger.
    • Using the previously described technique, pry the housing on the right edge away from the trigger.
    • Rotate the trigger away from the logic board, past its housing.
  12. Xbox 360 Wireless Controller Triggers Replacement: step 12, image 1 of 3 Xbox 360 Wireless Controller Triggers Replacement: step 12, image 2 of 3 Xbox 360 Wireless Controller Triggers Replacement: step 12, image 3 of 3
    • Using a spudger, pry the trigger spring off its peg on the trigger housing.
    • Pull the trigger spring out of the trigger.
  13. Xbox 360 Wireless Controller Triggers Replacement: step 13, image 1 of 3 Xbox 360 Wireless Controller Triggers Replacement: step 13, image 2 of 3 Xbox 360 Wireless Controller Triggers Replacement: step 13, image 3 of 3
    • Slide the trigger toward the right side of the logic board, and rotate it clockwise.
    • Remove the right trigger from the logic board.
    • To remove the left trigger from the logic board, follow the procedure previously described for the right trigger.
Brett Hartt
128,027 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,524 Guides authored
Past 24 Hours: 8
Past 7 Days: 68
Past 30 Days: 226
All Time: 83,268
