Introduction
Use this guide to remove the gray plastic top vent from your Xbox 360.
Grasp the hard drive assembly and press the release button while lifting its front edge.
Remove the hard drive assembly from the top vent.
The top vent is secured to the console via clips. The first two clips are located underneath the top vent closest to the faceplate, as shown in the pictures.
Insert the flat end of a spudger into the small gaps previously mentioned to release the clips.
To release the clips, work from the middle of the top vent.
While slightly lifting the front edge of the top vent, use the tip of a spudger to push the clips closest to the center of the top vent toward the inside of the 360.
Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox's upper case.
The last clip is hidden underneath the rubber foot nearest the back of the console.
Use the tip of your spudger to release the clip on the top vent nearest the back of the Xbox.
Remove the top vent from the 360.
