Nintendo DSi Top LCD Screen Replacement
Views: 46K
View statistics:
Past 24 Hours:
25
Past 7 Days:
158
Past 30 Days:
687
All Time:
46,033
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 13
13 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
In Progress
This guide is a work in progress. Reload periodically to see the latest changes!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Archived Guide This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Introduction
Go to step 1 ↓
This guide has been updated by iFixit staff! Read the new, official guide here.
A guide on how to replace the Nintendo DSi top LCD screen.
Parts
Tools
    1. Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
      Nintendo DSi Top LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
      Ask FixBot
    2. Nintendo DSi Top LCD Screen Replacement: step 2, image 1 of 1
      • L Button.
      • Top of the battery pack.
      • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
      Ask FixBot
    1. Careful: steps 3-4 are sourced from a guide that's marked as in-progress.
      Nintendo DSi Top LCD Screen Replacement, Motherboard: step 3, image 1 of 2 Nintendo DSi Top LCD Screen Replacement, Motherboard: step 3, image 2 of 2
      • Remove 4 Phillips screws from the board.
      • Lift the main board from the bottom end and flip it over to reveal the last connector.
      • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
      Ask FixBot
    2. Nintendo DSi Top LCD Screen Replacement: step 4, image 1 of 1
      • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
      • The motherboard should now be free from the rest of the device.
      Ask FixBot
    1. Nintendo DSi Top LCD Screen Replacement, Bottom Case: step 5, image 1 of 1
      • Remove the rubber front-panel button membranes from the device. Pay careful attention to where the buttons go, so you can replace them correctly.
      • A/B/X/Y button assembly
      • Select/Start button assembly
      • D-pad
      • Power button
      Ask FixBot
    2. Nintendo DSi Top LCD Screen Replacement: step 6, image 1 of 2 Nintendo DSi Top LCD Screen Replacement: step 6, image 2 of 2
      • Remove the plastic buttons and keep them in a safe place.
      • All of the buttons have "key" notches to prevent them from being inserted incorrectly (backwards or in the wrong place), but it can take a while to figure out where everything goes if they get shuffled around.
      Ask FixBot
    3. Nintendo DSi Top LCD Screen Replacement: step 7, image 1 of 2 Nintendo DSi Top LCD Screen Replacement: step 7, image 2 of 2
      • Flip the case open, and push the lower screen assembly out of the frame.
      Ask FixBot
    1. Nintendo DSi Top LCD Screen Replacement, Top LCD Screen: step 8, image 1 of 1
      • To make the repair easier, we recommend removing the bottom LCD screen prior to replacing the top LCD screen.
      • Using a spudger, or similar tool, pry out the 4 square screw covers.
      Ask FixBot
    2. Nintendo DSi Top LCD Screen Replacement: step 9, image 1 of 1
      • Remove 4 Phillips screws with a #00 Phillips screwdriver.
      Ask FixBot
    3. Nintendo DSi Top LCD Screen Replacement: step 10, image 1 of 1
      • Place a plastic opening tool between the front panel and top edge of the outer case. Slide the tool along the edge as needed to prop open the case.
      • With the screen facing you, slide the screen side down with your thumbs to separate the screen from the cover.
      Ask FixBot
    4. Nintendo DSi Top LCD Screen Replacement: step 11, image 1 of 1
      • Remove the antenna from the bottom left of the device.
      • Remove the microphone from the top of the frame.
      Ask FixBot
    5. Nintendo DSi Top LCD Screen Replacement: step 12, image 1 of 1
      • Use a spudger to pry the camera out of its place.
      Ask FixBot
    6. Nintendo DSi Top LCD Screen Replacement: step 13, image 1 of 1
      • Cables for the components in the upper half of the device run through the hinge, which must be carefully disassembled before continuing.
      • Start by pushing the sliding shaft in the hinge on the opposite side of the wires/ribbons.
      Ask FixBot
    7. Nintendo DSi Top LCD Screen Replacement: step 14, image 1 of 1
      • On the reverse side of the casing, insert the spudger onto the surface of the sliding shaft just left of the LED light channels.
      • Push the sliding shaft completely through the hinge until it stops and the hinge is released.
      Ask FixBot
    8. Nintendo DSi Top LCD Screen Replacement: step 15, image 1 of 1
      • The right side of bottom case should separate from the top case when you remove the sliding shaft.
      • Do not pull up too far or the wire hinge may be damaged.
      • Slide the top case to the right to separate the joint.
      • Weave the wires and ribbons through the wire hinge to completely separate the top and bottom casings.
      Ask FixBot
    9. Nintendo DSi Top LCD Screen Replacement: step 16, image 1 of 2 Nintendo DSi Top LCD Screen Replacement: step 16, image 2 of 2
      • The speakers are soldered to the ribbon cable attached to the upper LCD, so they must be removed at the same time as the LCD.
      • Lift the top LCD out of the plastic frame. Carefully thread the ribbon cable out of the hinge to avoid damaging it.
      Ask FixBot
    10. Nintendo DSi Top LCD Screen Replacement: step 17, image 1 of 1
      • To remove the speakers, use a spudger or a similar tool to gently pry them off.
      Ask FixBot
rjcamero
56 Reputation
3 Guides authored
Cal Poly, Team 6-1, Maness Fall 2009 Member of Cal Poly, Team 6-1, Maness Fall 2009
CPSU-MANESS-F09S6G1
5 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 25
Past 7 Days: 158
Past 30 Days: 687
All Time: 46,033
